Results 1 to 16 of 16
Thread: Custom door handles & locks.....
    Awaiting Activation Morbid Intentionz's Avatar
    Mar 2003
    89 accord lxi sedan
    Indianapolis
    For security reasons and show reasons I came up with a cool idea. What do you think bout gettin like the brake lines from bikes and shavin off the locks and movin the door handles somewhere else.....i dont know yet got the idea look in my head. So like if someone brakes your window......lookin for a door handle or the lock to open your door and cant find them they will get shitty and run off and possibly never do it again............good idea or not.
    88fasthatch's Avatar
    88 accord dx hatch
    santa rosa, ca
    Way too much work!!!
    17"enkei cdr 9 with falcon tires
    dropped to the ground
    k@n inhale and flowmaster exhale
    LX User Luis 89LXi's Avatar
    Nov 2002
    89 LXi coupe, 89 LX 4-door
    Monterrey, Mexico
    if your car has an alarm whit a channel available, you could use a solenoid attached to the line in the latch, inside the door to unlock it, i talking on the aftermarket solenids that use in the trunk. Well thats the idea. Then you could shave/hide the door handle. open by press the aux button on the remote.
    let get you a fast diagram of it . . . . .
    Nov 2002
    Monterrey, Mexico
    OK this is my idea on shaved handles:
    you will use a solenoid like the ones in aftermarket trunk release, wired a relay from an available wire channel in your alarm. if you attach the wire from the solenoid in the line that moves when you push the door handle you could open the door (first you have to unlock it) the solenoid will act as your hand pushing the door handle and the spring on the chassis will push the door outside a bit but will not close again. you got it ???.
    this is my draw:
    you could use the line thats attached to the external door handle or internal whichever has room for the solenoid, since the door are unlocked the solenoid will pull the line to open the latch.
    hope i was clear a bit. i never does but i think it could work, just work on the idea and keep us updated.
    Luis Z
    SEi User toastyghost's Avatar
    Mar 2002
    a 93 z34 that's getting parted out, an 86 accord lx that now lives in a j/y, and a 90 camry le that the state no longer allows me to drive. soon to be replaced with an aprilia rs50 or a derbi gpr.
    Harrisonburg VA
    I'm with 88fasthatch on this one, too much effort for not enough gain. That's just a personal thing though... don't let me discourage you.
    ~<+045+ygH05+>~
    Washington
    a friend added a proximity motion sensor to his car and added a solenoid like the other guy was saying. The cool thing is the way he designed it is you walk up to the fender tap 3 times in a spot and the alarm turns off and the door opens.
    You can imagine relm of possibilities this makes for theves. If someone watches him more than once they have the master key. If the kids bump it the door opens. Cool but needs more security. And for those of you that overthink things. His alarm was a starter kill, glass break sensor and door, trunk, hood pins. No motion or other proximity sensors. Basic but cool.
    Another thought I was going to try this winter. He said the rear handles froma 4 door fit the front doors so if you have automatic locks on your alarm you dont have to look at the key hole anymore that your not going to use anyway. Mike
    Mar 2003
    89 accord lxi sedan
    Indianapolis
    Im gonna try that...i like hands on projects and even if it dont go right ill have some insight for people who want to try.
    Vinny's Avatar
    Aug 2003
    Here, not there
    best of luck but I agree its wayyyy to much work
    Mar 2003
    89 accord lxi sedan
    Indianapolis
    Ok...so what makes the power doo locks unlock? Is there like a solenoid to pop it up and if there is is it mounted in the door?
    Mar 2003
    89 accord lxi sedan
    Indianapolis
    Ok i found out in my Haynes Manual that they are controled by actuators. SO why couldnt you get another actuator And set it up Like you were sayin in your drawing?
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    I shaved my locks by getting a pair of rear door handles off a junkyard 3g of the same color as mine. They're a direct fit and I use a keyless entry unit to lock and unlock the doors.
    Cool, yet cheap (10 for handles, 30 for keyless system) mod that looks good.
    glorious!
    Mar 2003
    89 accord lxi sedan
    Indianapolis
    I got a viper with keyless entry . I might just get another set of handles if this fails. i found out the hard way why you cant use actuators cause go up and stay up until they switch back down .. unlike the solenoids where they pop
    Mar 2003
    89 accord lxi sedan
    Indianapolis
    Now my question is that to use the aux button(channel 2 (-)) is says that i have to hook up a relay to it. So should i hook up a constant power(+) to it and run all my wires then hook up the channel 2 to the negative side?
    Sabz5150's Avatar
    Richmond, VA
    Positive pulse or negative pulse system? If it's negative pulse (which it most likely is) then yes, that is the correct way to set it up.
    glorious!
    Nov 2002
    Monterrey, Mexico
    You need to use a Relay if is negative pulse. I don't see any + pulse for Aux Channels. As you says in actuators ther have a kind of motors that pull outward in a button push and inward in another botton push and they dont have enough power to move the door handle i guess.
    I like that idea on rear door handles, but i guess your point is shaved door h. try the solenoids, here in mexico thery're almost $13 dls each whit all wiring and the realys are less than a dollar. They're so cheap just to try.
    Luis
    Nov 2002
    Monterrey, Mexico
    you can't use the solenoid without a relay, you can damage your Alarm system, the relay acts as a bridge to leave the power runs tru the solenoid whitout the ( - ) in aux gets in contact whit the solenoid, is hard to explain, the aux channel is 3 amp i guess as i told you just to make a bridge in the relay, the solenoid can blow a 10 amp fuse (it happens to me) imagine that can do by the aux wire to the system if you plug it alone, even fused.
  1. door handles?
    By AlfredoPDX in forum Classic Honda Community Chat
    Last Post: 08-12-2007, 04:07 PM
  2. 2 door and 4 door model door handles interchangeable??.............
    By detroit313 in forum Interior & Exterior Care
    Last Post: 04-27-2007, 05:22 PM
  3. Power Door Locks and Shaved Door Handles
    By w00tw00t111 in forum Interior & Exterior Care
    Last Post: 12-11-2004, 10:04 PM
  4. door handles
    By blazin3gen in forum Interior & Exterior Care
    Last Post: 02-03-2003, 11:50 AM
