Results 1 to 6 of 6
Thread: A20A / Changing The Timing is Retarded!
    Jul 2003
    1987-Gen2 Honda Prelude-FF-2.0L-MPFI-4 Cyl-5 Spd-PWR-BLK
    Ottawa
    OK...all I'd like to say is that changin the timing on the A20A engine is stupid!
    that window for viewign the flywheel....garbage...you cant see crap through that little window!
    PLUS...my ludes hood opens the wrong way so I have to take it off to check the timing!
    Anyone feel my pain?
    SEi User Dibbs's Avatar
    May 2003
    '86 LX-i Hatch
    Houston
    Nope....don't have a 'Lude.
    Quote Originally Posted by kroy
    Mad props to you if you can pull it off, you can change your name to slowassoldschoolswap :thumbdown
    LXi User Magny's Avatar
    Aug 2003
    1987 Honda Accord LX
    Cali Baby
    lol dude, if ya wanna mess with the timing, get in there lossen the bolts on the dis., turn on the car, go move the whole dis. ass. until you get the right feel for things. just remember one way is retarding it and the other way is advancing it.
    I retarded mine by about .5 to 1.0 so that way when the piston is a little past TDC the spark ignites the gas to create downpressure, thus putting pressure on the piston as it goes down. so more or less like riding a bike to go foward. to me its a better way to put less strain on the piston rods while it is at TDC.
    Also a note to that, my car has gotten alot faster doing this. I shoulda taken it to the track to do the before and after times, :lol damn it
    3geez Newbie
    Sep 2003
    1986 honda prelude
    Harrisburg Pa
    i feel ur pain bro, i got a lude lol atleast the hoods come off easy on the ludes!
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    My friend had an 87 Lude 2.0Si, and yes we had to remove the hood to adjust the timing. As for my 3g, I've stripped out quite a bit of the junk that usually hangs about near that hole (PS lines, A/C lines, condenser, etc etc etc. So it's easy to see the needle through that little hole.
    glorious!
    Jul 2003
    Ottawa
    DUDE! I KNOW!
    You gotta look in the window to adjust the timing properly man! For sure I'm using the dist but you gotta use a timing light too!
    ALSO...you said you retarded your timing so you get the spark after TDC...you cant do that. Its called compression det. If your spark plug does not fire before the piston reaches TDC that gas is going to explode just from the pressure and because the explsion does not form from one place it creates shock waves and you hear a knock!
    If you want more power run a higher octane gasoline and advance your timing. High octane gas burns slow but you get more POW from it so advance the timing BEFORE TDC so total gas expansion occurs 2-8Degrees AFTER TDC.
    Your engine would not run with the timing set to TDC. The gas would explode from the pressure at TDC and not finish exploding until the exhaust UP stroke.......pumping loss my friend!
    AND...I really hope you are using a timng light to do your timing....I tried to do it by ear for a while but you gotta use that light.....its a lot better!
  1. timing belt MAXIMUM mileage before changing.
    By detroit313 in forum 3geez Accords
    Last Post: 06-07-2006, 11:41 AM
  2. Replies: 8
    Last Post: 05-18-2006, 06:27 PM
  3. timing retarded 12 degrees
    By johnwc723 in forum 3geez Accords
    Last Post: 02-21-2004, 06:32 PM
  4. Changing the timing belt
    By Topnikko in forum 3geez Accords
    Last Post: 07-11-2003, 02:25 PM
  5. [Engine & Transmission] Change your timing belt (changing oil seals not included)
    By accordlx in forum How To
    Last Post: 05-16-2002, 05:36 AM
