Results 1 to 10 of 10
Thread: i cross tred my spark hole in the block
    Aug 2003
    i cross tred my spark hole in the block. i tap it out but the spark plug do not go down all the way. i don't fell too much powe lost. it all most the same. should i leave it because it is work or get a mechanic to push it down more. in the long run will it damage my motor.
    I'd go to a machine shop who will have no trouble getting it out and putting an insert in.
    LXi User Magny's Avatar
    Aug 2003
    1987 Honda Accord LX
    Cali Baby
    it possibly will depending on the clearance, but yeah check with the mechanic to make sure that it gets seated the right way. if ya dont you got a rocket ready to shoot through your hood just about for not getting seated right. but thats my opinion on the matter.
    how did you cross thread it anyways, you know your supposed to start it in by hand first. also it doesnt stop that fast if you did start it by hand. usually what i do is make sure the plug still wobbles when i screw it in until it seats.
    2.0Si User zero.counter's Avatar
    2006 Nissan 350z
    Does school count?
    It might either make contact with internals or allow foreign particles to flow in through the bad tread, assuming that the gap on the bad tread is that wide or big. Compression will be lost as well, resulting in some lost power, again depending on your particular circumstances.
    natsugusa ya
    tsuwamono domo ga
    yume no ato
    May 2003
    88 Accord LX 88 Accord LXi
    Not a good idea to leave it like that. It might seem like it's running all right, but could end up causing bigger problems down the road. You know it's not right, the time to fix it is now.
    shepherd79's Avatar
    Falling Waters, WV USA
    i would get thread maker, and try rethreading the hole.
    if you leave the way it is right now. spark plag may fly out the cylinder head and it can cause more damage.
    if you don't know how to use thread maker, go to the shop.
    Aug 2003
    "how did you cross thread it anyways, you know your supposed to start it in by hand first. also it doesnt stop that fast if you did start it by hand." the power steering hose was in the way so it mess up my position. i was not doing it by hand. i got all 3 in right but the last one wasn't.
    Aug 2003
    i want to now if this happen to any body than me. just to make me feel good. becaues it is a foolish misstake
    Aug 2003
    some mechanic down want to do it because they are do not want to make it in a bigger problem.
    SEi User Dibbs's Avatar
    May 2003
    '86 LX-i Hatch
    Houston
    The guy who owned the car before me kept his service records in his owners manual. He went to the Honda dealer every time. When I changed the plugs on my car for the first time, I found that the tech (at the dealer) who replaced the plugs on the car the time before had cross-threaded 2 of them! Talk about pissed! So i guess you shouldn't feel TOO bad considering you X-threaded only one of them.
    Hope that makes you feel better
    Quote Originally Posted by kroy
    Mad props to you if you can pull it off, you can change your name to slowassoldschoolswap :thumbdown
  1. Stripped spark plug hole
    By conozo in forum 3geez Accords
    Last Post: 07-03-2007, 07:21 AM
  2. Damn spark plug hole...
    By mix4 in forum 3geez Accords
    Last Post: 07-02-2007, 02:18 PM
  3. spark plug hole threads
    By Silver86LX in forum 3geez Accords
    Last Post: 03-20-2004, 11:33 AM
  4. What Is This Hole In The Block?(56k maybe)
    By HondaBoy in forum 3geez Accords
    Last Post: 03-14-2004, 09:45 PM
  5. spark plug hole stripped
    By 88accord in forum Performance
    Last Post: 11-03-2003, 07:18 PM
