I do not know why but I have a terrible power loss when I drive at night. When my lights are on the RPM ind jumps and the engine seems to sputter. I have no problem at all during the day. (unless I put a large power load on the system by turning on the lights)
I do not think that it is my altenator. I have 14.59 vdc at idle. The car idles fine when I remove the battery cables while running. I replaced all battery cables after the trouble started thinking that I might have a bad cable. Nothing changed. I checked all the fuses and all the connections. Nothing.
The only thing that I can think of that I have not checked is that the ACCEL coil might be bad or maybe the Altenator might not be putting out the AMPS that it should. The Alt does whine a lot. I mean A LOT.
Does anyone know what else might be bad? And how do I fix it?
Thanks in advance
Techno
