Results 1 to 4 of 4
Thread: My car turns over but won't start
    Jul 2003
    1989 Accord Coupe DX
    West Chester, PA
    Question My car turns over but won't start
    It started last night when I tried to start the car, it turned over and started for a few seconds. I started to pull out of my driveway and it stalled. Since, I have not been able to get it running. It almost sounds as if the engine isn't getting any gas, but I have no clue what's up. Can somebody tell me what's up? I mean it turns over, but won't start.
    What's old and 200lbs heavier than a 2000 Toyota Celica?
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    Here is how you would check if there is gas going to the carb:
    Pull the fuel line off of the secondary fuel filter (hood area) and have someone turn the key. There should be fuel coming through the line, if not then check the filters and pump. It is also a good idea to syphon the fuel into a jar of some sort so you don't spray everything with fuel when testing. Sounds like your filters may be the culprit. Check the filters and see if they are clogged. They are cheap parts that are easy to replace.
    Hope you find this helpful.
    3axap.
    Sep 2003
    1988 Honda Accord LX
    Ajax, Ontario
    could be fuel pump
    Jul 2003
    West Chester, PA
    Solution found... as I was mounting a relay box for fog lights I cracked the circuit board for the fuel pump and alternator behind the fuse box. I'm an idiot. Thanks for the help '89 abd Jay.
  1. Engine turns but it won't start...
    By 1989accordaz in forum 3geez Accords
    Last Post: 01-31-2010, 06:33 PM
  2. engine turns but will not start
    By erotomania in forum 3geez Accords
    Last Post: 08-27-2005, 03:54 PM
  3. Car wont start, turns over, no firing at all.
    By brian4g63 in forum 3geez Accords
    Last Post: 11-24-2004, 08:41 PM
  4. Car Turns Off!!
    By rleyba in forum 3geez Accords
    Last Post: 11-16-2004, 01:11 AM
  5. car start's than turns off (what's the problem?)
    By BIGEEZ in forum 3geez Accords
    Last Post: 10-15-2004, 12:05 PM
