Results 1 to 6 of 6
Thread: hand brake help
    Mar 2003
    honda/acord aerodeck 1988
    nottingham uk
    hand brake help
    iv got a accord aerodeck 1988 the hand brack dont work on one side its got disk brakes all roung can some one help me with this please
    3Geez Veteran 87AccordsterLx's Avatar
    Nov 2001
    1991 Supra Turbo W/ 12k Miles
    Wyotech @ Laramie, WY
    -> moved to the "Technical" section...
    ~Nathan~
    "There's always something waiting at the end of the road. If you are not willing to see what it is, you probably shouldn't be out there in the first place."
    ~StOcK PiCs~
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    Ok, this could be cause by a number of things. My first suggestion would be for you to download the Shop Manual from Paul's Site I think that your problem is probably caused by a fault in cable connection(s). Check the adjusting connections in the center console, and also inspect the rear brakes and see if the cable got unhooked at the caliper. The shop manual should tell you what other trouble areas there may be.
    P.S.: Seems like you have one of the more rare top of the line Aerodecks. :pimp:
    I hope you find this helpful.
    3axap.
    Mar 2003
    nottingham uk
    i take the cable of the caliper and it not releasing it self when it releases it works ????
    accord exi '88, A20A4
    RO
    had the same problem for a couple of weeks ago...it turned out that was whole mechanism was rusty/dirty since i never use the hand brake
    what i did (if the cable is not broken of course):....have somebody sitting in the car and pull/release the hand brake all the time....unde mean time, get some lubricant on the hand brake mechanism (attached to the caliper right behind the disk), and help the brake wire (with a screw driver) to 'go back' every time the person in the car is releasing the brake...do it for ..like 10 min or so
    it worked for me (and now i am using the handbrake )
    peace!
    Mar 2003
    nottingham uk
    thanks dude ill give it a go let you no if it works for me
  1. polished out hand brake
    Last Post: 11-24-2006, 08:08 PM
  2. hand brake
    By Aer0deck in forum 3geez Accords
    Last Post: 01-18-2006, 02:35 PM
  3. hand brake help
    By snakeman in forum Classic Honda Community Chat
    Last Post: 09-06-2003, 09:30 AM
  4. E-brake ( hand brake )
    By ACCORD EX in forum 3geez Accords
    Last Post: 05-05-2003, 01:05 PM
  5. Hand brake knob and gear stick ring removal
    By Rick in forum Interior & Exterior Care
    Last Post: 04-14-2003, 07:49 PM
