Results 1 to 13 of 13
Thread: Power steering leak
    1989 Accord LX
    Ontario Canada
    Power steering leak
    I've got a leak in the metal line that goes from steering rack to speed sensor. Rather than try to replace the compression portion, I was just going to cut out the bad part and reconnect using rubber hose right to the sensor. I figure this is just a low pressure line anyway. Has anyone actually been able to replace a corroded compression nut on the steering rack. I'm afraid to destroy the rack. What do you guys do when the metal lines go??
    Frank
    89 Accord LX / Carb
    shepherd79's Avatar
    Falling Waters, WV USA
    i just let them go. it doesn't bother me. i don't lose any power steering fluid.
    you can try it. i would recomend spraying with some PB blast just to make sure you will remove the nut.
    2.0Si User zero.counter's Avatar
    2006 Nissan 350z
    Does school count?
    Some tightened clamps on some pressurized rubber hose should work fine on the PS metal line. But you have to remember, there is a reason why they used the metal line in the first place.
    natsugusa ya
    tsuwamono domo ga
    yume no ato
    LX User DanG86LX's Avatar
    Jun 2002
    86 Accord LX, carb, AT
    Edmonton, Alberta
    "..and reconnect using rubber hose right to the sensor. I figure this is just a low pressure line anyway."
    Wrong assumption, the fluid pressure in system is ~ 1200psi. That's why all pipes there are metal!
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    The high pressure supply line to the rack is at 1200 psi, but the speed sensor lines are likely much lower. On my car the hoses that actually connect to the speeds sensor are rubber and held on to the metal lines and speed sensor fittings by hose clamps.
    Frank, are you planning to remove the whole metal line or just trim off a corroded portion? You mentioned both the end of the line near the speed sensor and the nut that secures the line to the rack. The control valve housing on the rack is cast aluminum so be careful when working with it.
    Mike
    LXi User jlaccord89lxi's Avatar
    '01 Accord EX Coupe
    Nova Scotia, Canada
    why the hell does a power steering line go to the speed sensor anyway??? I didn't think we had speed-sensitive-steering in our 3gees?
    Vinny's Avatar
    Aug 2003
    Here, not there
    Thats about as good a question as why the hell do we have a cooling line for our power steering? Mine was leaking there when I bought the car. First time I ever had to pull a bumper off to change a power steering line
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    The cooling line lets the PSF cool after being compressed by the warm pump. I'm not sure how hot the fluid is after passing through the pump, but I'd like to think Honda put the cooling loop on our cars for a reason.
    The lines to the speed sensor are for the speed-sensitive power assist. You may have noticed it's much easier to turn the steering wheel in a parking lot compared to on a highway--or maybe you didn't, either way it's there. The speed sensor is a little pump that reduces the fluid pressure available to the rack as your speed increases.
    [editted typo]
    Mike
    May 2003
    88 Accord LX 88 Accord LXi
    Interesting. I'll have to pay attention and see if I notice the difference.
    Nov 2000
    It's an older type of speed sensitive power steering that's "all-or-nothing" rather than the variable assist found on the 4g and newer Accords.
    Also, the fittings at the rack are not compression fittings. They are flare fittings. If you buy the right size flare nut wrench you should be able to break the nut loose. The problem with using rubber hose is that even though the hose may be able to take the pressure the metal tube you are clamping it to is smooth rather than barbed so there is nothing for the hose clamp to "grab" onto.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    How the does continuously increasing rotating speed of the speed sensor as the car accelerates produce an 'all or nothing' steering assist? At what speed does this assist turn off?
    If I remember right, the Honda manual says that the valve in the speed sensor only works to keep the sensor from raising the pressure when moving backwards, otherwise the sensor works like a pump, pulling fluid off the high pressure side of the rack.
    Mike
    1989 Accord LX
    Ontario Canada
    Holy cow!.... I believe the sensor was designed to cut out power assist at about 30KPH. This gives a more natural feel at higher speeds. Anyhow...I cut out the bad line and used a 1/4 compression fitting...worked real nice!..Incidentally they are not all metal lines. Only the main supply from pump is high pressure. This is the only braided steel hose on my car.
    Frank
    89 Accord LX / Carb
    Nov 2000
    Well, I believe my shop manual says that it "cuts" power assist at around 35mph. After driving the car for a week without P/S I would say that you actually have some level of power assist at all times. I do recall that the 3g had a less sophisticated system that basically gives you max or min power assist (v. all-or-nothing)where 4g and newer gives you a truer "variable" power assist. I can say from experience, though, that a P/S system with the belt removed SUCKS!
  1. power steering leak
    By RSXtacy in forum 3geez Accords
    Last Post: 12-10-2004, 07:06 PM
  2. power steering leak
    By pixiesfan78 in forum 3geez Accords
    Last Post: 03-09-2004, 09:52 PM
  3. power steering leak need help
    By neoblue89lxi in forum 3geez Accords
    Last Post: 01-15-2004, 11:07 AM
  4. power steering leak !
    By ACCORD EX in forum 3geez Accords
    Last Post: 09-11-2002, 09:32 PM
  5. Help!! Power Steering Leak
    By CASH24 in forum 3geez Accords
    Last Post: 07-07-2002, 09:48 AM
