Results 1 to 17 of 17
Thread: what how to's are needed ! ??
    Oct 2001
    87 Accord EX , 5spd , Manual
    Smile what how to's are needed ! ??
    hi everybody !
    if you need any how to 's just post them here !
    and i 'll see if i can make any of them !
    internal engine how to's will be dificult to create sorry guys !
    MIKE
    SEi User gr3k0sLaV's Avatar
    Feb 2002
    1998 VT Commodore 50th Anniversary Edition
    Geelong, Australia
    maybe something on repsraying the car, or something giving some info on that.
    maybe a howto on engine swaps, or at least some decent amount of detailing of what goes into a b16a and b20a swap, the faqs just dont provide enough detail. There are other things to take into consideration such as what happens with the sensors, wiring, vacuum controls, etc.
    a howto on wiring your car for a sound system, this would be useful for people who wouldn't have done it themselves but want to do it themselves and dont have a clue.
    how to remove the camshaft (i could be wrong, is it this already up?)
    how to remove the front and rear bumpers
    how to install underbody neons and wire them
    how to remove / fix / or whatever the electric antenna
    how to install an electronic immobiliser
    how to install a remote starter for carbs and efi
    Cocaine's A Helluva Drug! - Rick James
    I really fracked things up for you Bill - Colonel Tigh
    Girl we couldn't get much Higher! - Light My Fire
    Oct 2001
    the electric antenna is a good idea ! while already doesn't work at my car so i can tear it up as i want !
    camshafts > difficult ! ( i won't tear my engine not right now )
    underbody neons > don't have them around here !
    front and rear bumpers ! > i belive that if i will remove mine they will never bolt on again !!
    what about the first one do you mean spraying the car ?
    MIKE
    Feb 2002
    Geelong, Australia
    Something about tips and ideas when doing your own repsray, and what's required when doing it,
    ie primers, paints and all that.
    You should get other people to make/post how-to's for other things, that way we can have a nice phat d/base of it.
    I had this idea but no one went for it, of putting together a decent meaty document of howto's, faq information, engine work, like an online book on accords. Some sort of collaborative project and actually publishing it. Possibly using the money to help fund our 3gee cause and get some attention...
    the book could also be full of the how to's, but photo's of cars, examples of work.
    May be a good way to get us some REALLLY grand attention.
    DX User s0crates82's Avatar
    1995 Dodge Avenger
    SoCal... Lancaster to be specific.
    Automatic to Manual Transmission conversion!!!
    -Tim
    You sold me queer giraffes. I want my money back.
    87accordlxi's Avatar
    Oct 2000
    here's an idea... check the How-to's we already have. auto to 5spd conversion
    - Joe
    Oct 2001
    man take it easy on me ! !! i am not that good !
    about sprayin the car i have some experience ! i will publish it with some pics !
    MIKE
    Feb 2002
    Geelong, Australia
    Actually it Just remembered, a GOOD howto on adjusting timing and the Idle.
    See timing, the haynes manual has a lousy and messed up description on adjusting timing, part of it is on one page and more details are on another.
    Also how to adjust the timing to correct spec (ie what is CORRECT spec) and how to adjust it to suck a bit more performance.
    Next is a how to on adjusting the EFI idle. And whether or not to disconnect vacuum lines, etc.
    Those two are really needed.
    Also some pics with te valve adjustment ones....
    Oct 2001
    EFI adjustment ?? i have a carbed ! and i did a how to on the carbs already after it got the shit out of me !
    valve adjustments ! don't really know too much !
    timing !? i am still confused till now !
    MIKE
    1987 accord sedan
    Halifax
    you gota look around on teh net...theres a lot of how tos on other sites that although not specific to our car will be genericly the same....like the how to on building your own Cold Air Intake etc....
    all the same stuff...adn theres good books out there that will help you too(forget about teh factory manual it's like reading astro physics or something)
    I got a Chiltons and a Haynes...what one leaves out the other has coverd.....
    nothing
    Oct 2001
    you're right about that ! :lol
    MIKE
    Oct 2001
    the PAINTING YOU CAR how to is done ! it's in thehowto's , enjoy guys !
    MIKE
    LX User hondamotorz's Avatar
    1989 honda accord lxi
    gastonia,nc
    edit: dangit i forgot to look at the date on this board
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    Houston, Texas (Home of the Quicksilver project)
    How To Search. I think it would help a lot of people.
    "Feed their greed with your need for speed"
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Quote Originally Posted by hondamotorz
    a lot of the how-to's have been made already... but you can still add suggestions.
    Vanilla Sky's Avatar
    1999 Penalty Box
    i've got several FAQs i keep meanign to write... possibly a how-to or two...
    I need to redo my how to's, but I'm too lazy. Spring Break
  1. Mot Fail!! Big Cost. Advice And Or Offers Needed! Steering Rack Needed!
    By ESDEEZ in forum Classic Honda Community Chat
    Last Post: 08-12-2007, 08:19 PM
  2. Help needed
    By slickrick in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-23-2004, 08:15 PM
  3. HOW - To's needed on :
    By gr3k0sLaV in forum 3geez Accords
    Last Post: 05-17-2003, 01:11 PM
  4. NEEDED for the FAQ! ECU pin-out
    By carotman in forum General Engine Swaps
    Last Post: 12-26-2002, 06:55 PM
