Results 1 to 4 of 4
Thread: vacuum leak?
    May 2003
    1988 Accord LX
    Cape Breton, Canada
    Question vacuum leak?
    i just finished replacing the upper control arm on the front passenger side and put the car back together. the car was on blocks for 4 days or so due to some problems getting parts in my area.
    any way once i started it up to try out my new arm a new problem arrived.the car now idles lower than usual and it sputters . i have to constantly tap the gas in order to get anywhere without stalling.the only thing i touched was the box in the upper left corner with all the vacuum lines coming out of it,that i can think of that i could have messed up.
    is this a vacuum prob? did a line inside or outside the box come loose..how do i check? can i open the box? or could it be something completely different?
    help please!!!
    May 2003
    88 Accord LX 88 Accord LXi
    Sounds like it could very well be a vacuum problem. You can take the top off and look in there. Make sure all lines are hooked up, and check for cracked lines at fittings.
    May 2003
    1 more thing. Did you connect the electrical connectors back to the box?
    May 2003
    1988 Accord LX
    Cape Breton, Canada
    i did not have to disconnect any wires
    i'll open the box and look at the lines in the morn
  1. Vacuum leak questions
    By b_radsmizzle in forum Carburetor Tech
    Last Post: 11-21-2009, 11:31 AM
  2. Vacuum leak + Smoke
    By 2drSE-i in forum 3geez Accords
    Last Post: 10-29-2009, 08:06 PM
  3. STILL not working, vacuum leak? help
    By Wipeout in forum Carburetor Tech
    Last Post: 08-09-2004, 09:37 AM
  4. how do i know if i have a vacuum leak?
    By Dennis in forum Carburetor Tech
    Last Post: 05-12-2004, 12:43 PM
