Results 1 to 7 of 7
Thread: Fluctuating Idle
    carotman's Avatar
    Montreal South Shore
    Fluctuating Idle
    Well I got a fluctuating Idle problem
    here's what it does:
    I step on the gas and the revs go up no problem.
    When they go down, they drop too low and go back to normal in like 0.5 secs.
    SOmetimes it drops even below the 500 rpm mark.
    So far I changed my IAC valve (2 times with used ones) and my fast Idle valve....
    Any idea what could it be?
    I'm suspecting my EGR or maybe a leaking gasket.....
    The problem goes slooooowly away as the car warms up... if I drive the car for like 1 hour... the problem is almost absent....
    I need these parts!
    Oct 2001
    87 Accord EX , 5spd , Manual
    i had the same problem when cold ! now it disappeard after i changed my wire ! don't know if that's related !?
    MIKE
    Jun 2002
    89 Lx auto
    lol i have kinda the same problem but on whens it been hot out. mine will actually stall out at time so i think it might be something more.
    carotman's Avatar
    figured out my problem by myself
    Thanks for the replies tough.
    I need these parts!
    Oct 2001
    and what was it !?
    MIKE
    carotman's Avatar
    Well it's simple but complicated at the same time.
    My idle was a bit high and I decided to lower it a little. I turned the screw until it came to the idle specs. The thing is, I lowered it too much and the ECU didn't like that, so it sent a signal to the IAC valve as I was turning the screw, completely fooling me.
    So when I stepped on the gas, the revs went up to problem and the IAC valve closed. Then I let off the gas, the throttle closed, the revs dropped too much and the ECU was opening the IAC valve to compensate... but the ECU would have a 2 seconds delay which caused the fluctuating Idle..
    The correct way to adjust the Idle is to unplug the IAC valve so the ECU cannot compensate. You set it at 800 rpm and everything is fine.
    I need these parts!
    Oct 2001
    thank god i have carbed ! no damn ECU controling the shit !
    MIKE
  1. Erratic Idle, Fluctuating when using Electronics
    By CharvelM2 in forum Carburetor Tech
    Last Post: 06-16-2011, 02:00 PM
  2. Fluctuating Idle - Carbed '87 Accord
    By Lester Lugnut in forum 3geez Accords
    Last Post: 07-13-2005, 01:15 PM
  3. fluctuating tach??
    By 89accordlxi in forum 3geez Accords
    Last Post: 02-12-2004, 08:36 PM
  4. Help: Fluctuating Idle when Brake Pedal Depressed
    By ELM'sLX+CHL'sDX in forum 3geez Accords
    Last Post: 11-17-2002, 12:28 AM
  5. fluctuating power
    By ChthonicPowers in forum 3geez Accords
    Last Post: 09-29-2002, 06:36 AM
