Results 1 to 13 of 13
Thread: Best place for primary?
    2.0Si User pimp86LX's Avatar
    2005 Mazda 3
    Ontario Canada eh.
    well i have the carpet up, cause i was patching my rusted out floor, and before i put my subs in i was wondering what the best method is when running my primary power wire. I'm going to run a 4g primary into the cabin were it will be split for my subs and 6.5" amp
    whats the best place?..inquiring minds want to know! heh heh
    88 Accord LX
    run it along the side of the car.... and then run your RCA's on the other side...
    2005 Mazda 3
    Ontario Canada eh.
    .......wow.......is there a spot through the firewall that is commonly used? should i run it through the cross member? will it get pinched or squished?
    Jdub07's Avatar
    1986 Honda Accord DX Hatchback
    Newark, CA
    I ran the power wire on the passenger side of the car. There was a spot through the fire wall that had a black rubber cap and some lineing inside. I just put the wire through that hole and ran it under the carpet to the back. The RCA cables I ran under the carpet on the driver side. I suggested running it similar to this because your battery is on the passenger side anyway.
    86 accord dx wrecked
    2005 Mazda 3
    Ontario Canada eh.
    cool, thanks :smokin:
    86 si accord .... 5 speed :)
    depends which side you drive on :P
    i cant find any gaps anywhere silly (rh drive) car
    run the power on the same side as your speaker wires(after amped) and factory power wires
    keep the rca's away from any power soures if pos
    im trying to find a gap to run 1/0 guage to finish off my boot mounted battery install
    2005 Mazda 3
    Ontario Canada eh.
    also what guage wire should i wire for a 150x2 amp? i'm thinkin at the very least 8...should i run 4 as so i can split it later down the road?
    Jdub07's Avatar
    Newark, CA
    oh...thats right I didn't even thing of right hand drive. But yeah just keep the speaker wires and rca's away from power wires. From my very little understanding of audio I am pretty damn sure you can get as big a gauge as you want. You can't go to big but you can go to small....yet you must have the ground wire the same gauge as the power!
    2005 Mazda 3
    Ontario Canada eh.
    sweet, thanks!
    four gauge
    four is minimum guage to run.then you can split it down to eight in the boot if ya want
    if you are basically running more then 50-60amps then go for dual 4 guage
    2005 Mazda 3
    Ontario Canada eh.
    well my old setup has 8 but its a 150w so its not thaat bad......
    i'm going to have 4 to a split were it will be 8 for the subs and 8 for the amp that will drive the 6.5"s
    were can i find a spliter?
    anywhere
    u can get splitters anywhere ... from car audio shops electronic shops
    they are called distribution blocks... you get gold platted ones from prolly 10 bucks u.s your are after a 4 guage to dual 8 and you can get fused blocks aswell
    2005 Mazda 3
    Ontario Canada eh.
    awsome, thanks dude!
  1. Which O2 sensor is my Primary
    By Jared in forum EFI Tech
    Last Post: 09-01-2009, 11:05 PM
  2. Primary booster venturi help
    By Kagato in forum Carburetor Tech
    Last Post: 08-21-2008, 04:18 PM
  3. Primary fan won't come on, overheats
    By Boogerbub in forum 3geez Accords
    Last Post: 04-10-2005, 10:44 AM
  4. Primary Venturi Loose
    By TheAsianInside in forum Carburetor Tech
    Last Post: 09-02-2004, 06:56 PM
  5. Primary fuel nozzle
    By Techno in forum Carburetor Tech
    Last Post: 08-01-2003, 11:50 AM
