Results 1 to 11 of 11
Thread: Bumper signal lamps 86-87 and 88-89?
    Paul Aerodeck86's Avatar
    Jul 2001
    Accord Aerodeck 2.0 EX 1986
    Russia, Moscow
    Does lamps from Accord 88-89 will fit to my Accord 86?
    Signal lamps for 88-89:
    Signal lamps for 86-87:
    I found it for $15 - i think, it's not bad price!
    Does anybody know, may be anybody makes clear signal lamps?
    86 Honda Accord LXI HB 5-sp
    Central California
    They use different mounting systems, so the answer is no.
    Now I d
    SEi User gr3k0sLaV's Avatar
    Feb 2002
    1998 VT Commodore 50th Anniversary Edition
    Geelong, Australia
    *blerk* be creative paul, umm use epoxy or some sort of mounting design to fit it in. Just a matter of rigging something up, doesn't matter if the mounting's are different, as long as the sizes are right you shouldn't have a problem.
    You can use an epoxy resin of some description, that'd be the easiest, but the only problem you would have is removing the assembling to change the globes.
    I wouldn't mind getting my hand on a set too.
    Cocaine's A Helluva Drug! - Rick James
    I really fracked things up for you Bill - Colonel Tigh
    Girl we couldn't get much Higher! - Light My Fire
    Central California
    Glue them in, how are you going to replace the bulb's? I have a how to for making clears for the 86-87 cars. Start from the bottom picture and go up. If you have any questions, just ask.
    http://www.picturetrail.com/jims86lxih/865918
    If you can figure out a way to drill 2 mounting holes in a 88-89 turn signal assemblies, but you'd have to be spot on with your drilling, you might be able to make them work.
    Now I d
    Feb 2002
    Geelong, Australia
    Those bulbs usually have a pretty long lifespan anyway,...
    hmm say just glue it, and rip it out whenever you get a new globe!
    or you might be able to replace the globes by going under neath the car
    Feb 2002
    Geelong, Australia
    How'd u do yours jim?
    yours look sweet
    86 accord lxi
    hey jim, where did you get the clear reflector from?
    too much to list....sorry
    Nov 2000
    Wow. I just realized my old 72 Pontiac Catalina was ahead of its time. It had clear corner/turn signal housings up front with orange bulbs inside.
    I even did H4 halogen conversions on the thing.
    Central California
    Well after looking at sheet floresent lighting reflector panels and the pieces that come with floresent light's them selves, I concluded that their was not way I was going to use something that was paper thin and very brittle. I went looking at the junk yard for turn signal assemblies that could "donate" a good size piece of refector plastic. I found a late 80's jeep that had huge clear turn signal assemblies and cut them down for my clears. Nice an thick.
    Now I d
    86 si accord .... 5 speed :)
    hmmm weird
    i swapped all but the bumper mounted one onto my 86 from an 89
    didnt think to do the bumper one...looked the same
    might be the silly japanese models over here playing tricks again
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    The 86-87 are shorter than the 88-89. So they won't fit.
    Maybe if you cut them they will fit but, then it might look crappy.
  1. How to remove Front Bumper turn Signal?
    By SharkyX in forum 3geez Accords
    Last Post: 03-04-2017, 01:05 PM
  2. Replies: 13
    Last Post: 05-06-2013, 10:40 AM
  3. Bumper lights ONLY on for the turn signal?
    Last Post: 12-31-2007, 10:38 AM
  4. Jdm Black Front Signal Bumper Lights
    By slowazz86carb in forum Interior & Exterior Care
    Last Post: 07-25-2004, 06:49 PM
  5. Figured out how to make 86-87 turn signal clears (bumper)
    By Jims 86LXI HB in forum Interior & Exterior Care
    Last Post: 05-31-2002, 02:48 AM
