My transmission does not readily shift into fourth gear until warmed up completely. I used to be able to get it back to normal by changing the fluid (I have changed the fluid every 15K miles since the car was new). Now changing it does not seem to help. It shifts just fine and smoothly in the other three gears and shifts smoothly into fourth once warmed up. If it is not completely warmed up I can usually still get it to upshift into fourth once the RPM's get past 3,500.
Is this something I should just live with, or is it the result of some neglected adjustment that I don't know about?
