Results 1 to 11 of 11
Thread: How hard is the following to install.
    I need to install a new:
    Valve cover gasket
    oil pan gasket
    cam & crankseal gasket?
    also install brake master cylinder
    is there any faqs on these? or walk through on installs?
    May 2003
    88 Accord LX 88 Accord LXi
    Valve cover gasket is cake. Remove 3 nuts on top, 2 bolts on upper timing belt cover (not sure if this is needed but I did it and it was easy) and pull off. Make sure you torque nuts on reinstall.
    Oil pan is tough to get off. Do a search some members have been thru this and you might pick up some tips.
    Cam and crank seals you have to remove timing belt cover to gain access You might as well change the belt at the same time. The toughest part of that job is getting the crank pulley bolt loose. Again do a search, I think there is a how to for the t-belt.
    Master cylinder I never did, doesn't seem too hard. Disconnect lines (might need something to catch fluid) and remove mounting hardware. Bleed brakes when you are done.
    2.0Si User pimp86LX's Avatar
    2005 Mazda 3
    Ontario Canada eh.
    yah mast. cylinder is not that bad. I"ve done it on a few different vehicles.
    1988starter
    Guest
    This is a how to on camshafts I made it will show you how to get the valve cover timing belt cover and timing gear off to change the cranck/cam seal.
    Aug 2003
    1987/4DR/LX/5sp
    Big Ol' TEXAS
    Don't forget to bench bleed the m/c before you put it on. Otherwise = easy R&R operation.
    I'm fat and big boned.
    man I looked at the oil pan that thing looks like a royal pain in the butt compared to my DSM oil pan. That thing looks like you have to take off the downpipe, and a few other things. Looks like a long job!
    Yeah, most people (even the people who do all the work on their cars themselves) take it somewhere. It's a pain in the ass.
    where you located at? im in washington as well. I need to meet some people that know how to work on accords, its my g/f's car. So i have no clue.
    How much do you think it costs?
    I also have a few other things that i need to do.
    Cam and crank seals? that FAQ looked like a PITA as well.
    valve cover gasket is easy.
    is that a faq somewhere?
    SEi User danronian's Avatar
    1989 Honda Accord Lx-i, 1975 Chevrolet Malibu Classic
    Boyertown, PA
    I finally have understood what pita means, awesome acronym!
    lol. Do you know where the FAQ is for a oil pan install? Im searching and searching. Maybe its on another site? see for dsms we have a site called VFAQ.com Its visual faqs / installs. So people can install there own stuff step by step. Works realy good, im suprised you guys dont got one of these yet. If you do can u point me to it?
  1. How hard is it to install your own alarm?
    By LxAcc510 in forum Interior & Exterior Care
    Last Post: 06-03-2008, 10:19 PM
  2. How hard would it be to install this sub?
    By Raynor in forum Interior & Exterior Care
    Last Post: 03-29-2005, 09:40 AM
  3. It,s not hard to H 22 in a 3 gen
    By Ron Davi,s in forum General Engine Swaps
    Last Post: 06-07-2003, 06:56 AM
  4. how hard is it to do this?
    By NOAHS88accord in forum Interior & Exterior Care
    Last Post: 02-18-2003, 02:09 AM
  5. How hard is it to install front balls joints?
    By xbi0s in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-13-2003, 10:10 PM
