Results 1 to 11 of 11
Thread: Battery keeps going dead
    LX User Zwaag's Avatar
    Jun 2002
    87 Accord lx
    I need help. My car just sits, because I dont have a license and every time I get in it after it sits for a week or to, the battery is dead. Abso lutly nothing will work. Last time it happened I got a new battery. But, today I went out there and the same damn thing happened, and it's a brand new battery. Does any body know whats going on?
    2.0Si User pimp86LX's Avatar
    2005 Mazda 3
    Ontario Canada eh.
    well your not driving it, so it doesn't get a charge. And if it goes dead so quickly i would suggest you have an electrical 'leak' somewere
    My overhead light had bad wiring and caused the battery to die out fairly quickly
    May 2003
    88 Accord LX 88 Accord LXi
    Yep, by not driving the batt isn't getting charged. A few easy things to check are.
    1. Batt conections. Check that they are clean and tight. Check on the batt. and the starter (follow the + to the starter) Also check the other end of the - wire.
    2. The belt on the alternator, along with the connections. If you get it running check the output of alt. Put a volt meter on the batt. with eng running, you should have at least 13.75 volts.
    3. Also like stated above something could be draining your batt. Sometimes that is hard to find.
    LXi User 88accordhatchdx's Avatar
    Jul 2003
    2002 Dodge Dakota, 1969 Chevy Nova
    Portland, Oregon
    Yeah, I have the same problem as Zwaag. I'm having the electrical connections tested for a leak soon.
    I may only get 13-18 MPG, but try and follow me in the mud and you'll get stuck.
    Awaiting Activation Morbid Intentionz's Avatar
    Mar 2003
    89 accord lxi sedan
    Indianapolis
    I had that problem but i went through 6 batteries before i found a good one.
    Jun 2002
    87 Accord lx
    thanks for the hlep!
    Sep 2003
    1989 DX (LXI ENGINE SWAP)
    MIAMI
    SAME PROBLEM
    I have the same problem, i was convinced that it was my led lights for my alarm untill i went through about 7 batterries. I just take off my teminals now . electrical problems can cause money to fix.
    17 INCH RACINGHART F24'S 205ZR17- 40 (FALKEN)
    3 INCH DROP
    DC SPORTS HEADERS
    STRUT BARS(FRONT & REAR)
    FULL CAMBER AND CASTER CORRECTION(MIAMI CHASIS)
    TOXICO SHOCKS
    FLOWMASTER EXAUST(2.5 CUSTON EXAUST PIPING)
    CAI, FULL MSD, BOSCH PLATINUM+4 PLUGS
    STAGE 2 CLUTCH, PERFORMANCE FUEL FILTER AND PUMP
    RED AND BLACK LEATHER INTERIOR, PIONEER CD SYSTEM
    JL AUDIO SUBS, HOLLYWOOD AMPS
    ACURA LEGEND ALTENATOR CONV.
    COMING SOON: TURBO, SEI REAR DISC BRAKE CONV. SEI ARMREST &CASSETTE HOLDER.(got my armrest and cassette holder, black with armrest pad in red leather.)
    shepherd79's Avatar
    Falling Waters, WV USA
    if you gonna let it sit for along time, remove negative cable of the battery. this way it will keep the charge.
    Jul 2003
    Grey 1986 honda accord DX
    Trenton,NJ
    I have a questions...
    My "check battery light" comes on when I first start driving. It stays on for a couple seconds but the car continues to drive fine. This morning it blinked on and off about three times. the car has never cut off or anything. Does anyone know why this is happening? I even went out and bought one of those emergency jump chargers, just in case.lol
    Sep 2003
    MIAMI
    alternator
    check the connection betwen the alternator and battery terminal if eveything is ok, it most likeky is your alternator gooing bad.
    3 INCH DROP
    DC SPORTS HEADERS
    TOXICO SHOCKS
    Jareds 89 LX-i's Avatar
    Apr 2001
    Black '89 Accord LX-i sedan
    Mills River, NC
    Here's how to find your parastitic drain....(copied from what I told Joe)
    -digital multimeter with an 'amps' scale
    -some kind of jumper wire with alligator clips, or whatever you can think of to hold the meter probes to the battery post and battery cable
    Make sure all doors are closed, and all lights and everything are OFF. Set your meter to read "amps/milliamps". Disconnect the negetive cable from the battery and connect the negative probe from the meter to the negative post on the battery, then connect the positive probe from the meter to the clamp on the negative battery cable. Your meter is now set in series, thus the cars electrical system will still operate but goes through the meter on it's route. Give it about a minute or so for any electronics to settle down (ours don't really have many modules or anything so it shouldn't take long.... the Navi's/Continental/LS and some others you have to wait 45 minutes for everything to 'go to sleep'). The draw should not exceed 50 milliamps (.05 amps), and again make sure no lights or anything are on and doors are closed while doing this. If it exceeds 50mA, start pulling fuses one by one, watching the meter after each fuse. Don't put the fuses back in until you've found the source of your problem, and pull individual fuses before pulling any mega fuses. When you pull the fuse of your problem, the meter will go down to about 15-35mA. Once you've found that fuse, plug it back in and see if the draw goes back up (just to make sure), if it does then you've found you're problem (sort of). If it goes down, but it's still over 50mA, remember what that fuse controls and keep pulling fuses until it goes under 50, keeping track of each fuse that makes it go down. Look what the fuse controls and that will give you a good idea of what/where to look for problems. From there you can start unplugging individual components on that circuit, and you'll soon find out just what is draining it down. After it's all done, don't forget to put all the fuses back in their proper locations.
    -Jared
  1. Battery Light, Dead Car
    By ReaKtionary in forum Carburetor Tech
    Last Post: 08-05-2010, 09:08 AM
  2. dead battery
    By frantik in forum 3geez Accords
    Last Post: 01-07-2010, 05:20 PM
  3. battery light on after purching a new battery.
    By 60408CC in forum 3geez Accords
    Last Post: 10-04-2009, 09:26 PM
  4. Dead Battery or Bad Alternator?
    By blh1983 in forum 3geez Accords
    Last Post: 08-19-2007, 03:45 PM
  5. dead battery
    By teck in forum 3geez Accords
    Last Post: 02-03-2007, 07:20 AM
