Results 1 to 18 of 18
Thread: Car Wont Start/Please HELP !!!!!!!!!
    Jul 2003
    1988 lxi 2dr coupe
    Newport, Pa
    Unhappy Car Wont Start/Please HELP !!!!!!!!!
    Ok i hope someone can give me some good input.
    I was Driving home going about 55mph and my cars engine light went on and my car kind of like shut off. I tried pop starting my manual but it seemed like it couldnt even do that. it cranks good but never turns over and starts. i just paid 65.00 to get it towed so iom hoping it not something serious or not . my car wasnt overheating at all it just out of nowere lost all power and wont start the battery seems fine . Hopefully you geniuses can figure this one out or help in any way.... thanx
    Jun 2002
    87 Accord DX Hatchback 5 Speed
    Cocoa Beach, Fl.
    you might have blown a fuse, check all the fuses in the box by the battery, especially the main fuse.
    SEi User 89accord_lxi_coupe's Avatar
    Jan 2003
    Louisville, TN
    main relay? they are known to go out on our cars.
    Nolan
    check my profile
    I'm on AIM at Maxaccord3G
    I AM THE STIG
    Jul 2003
    1988 lxi 2dr coupe
    Newport, Pa
    i checked all of the regular fuses but i am unsure on how to tell if the big squre fuses are blown or not.
    Vinny's Avatar
    Aug 2003
    Here, not there
    Timing belt still there???? Noises when it died?????/ anything other than it just quit?????? Kinda vague on the description of whats goin on so all I can do is guess.
    Jul 2003
    1988 lxi 2dr coupe
    Newport, Pa
    no noises it all of a sudden died i just rechecked all the fuses and they seem ok . it cranks fine but just doesnt start im clueless any sugestions would be great
    Jan 2003
    Louisville, TN
    basically it cranks but just wont kick over?? that's what was wrong with mine and it was the main relay.
    Nolan
    check my profile
    I AM THE STIG
    Jul 2003
    1988 lxi 2dr coupe
    Newport, Pa
    is the main relay expensive to fix/ what exactly is it do
    Jul 2003
    1988 lxi 2dr coupe
    Newport, Pa
    what is the main relay is it expensive to fix?
    Jul 2003
    1988 lxi 2dr coupe
    Newport, Pa
    ive been working on it for the past hour and no luck . hopefully someone knows whats going on.....
    Vinny's Avatar
    Aug 2003
    Here, not there
    Search for main relay, I'll help you some but there more out there for you to find
    Are you getting spark???
    Did you check to make sure your timing belt didn't break?????
    Can you hear your fuel pump turn on?
    Main relays usually fail when its hot from what I've read. Hot days when the cars been setting in the heat with the windows rolled up, after things cool down it works.
    Also read this
    main relay
    and this
    main relay
    87 Accord LXi Hatchback
    Chicago
    First, u need to check if u have spark! Also, pull the distributor cap off and see if the rotor turns while someone in cranking it.
    The main relay USUALLY fails as a "no start condition when hot"... not that it cant be that though.
    let us know.....
    Jul 2003
    1988 lxi 2dr coupe
    Newport, Pa
    still need input cause it goes to get looked at tomorrow.
    Jul 2003
    1988 lxi 2dr coupe
    Newport, Pa
    Vinny's Avatar
    Aug 2003
    Here, not there
    c'mon ya haveto give us something to work with here. We've asked you about things to check and you haven't told us anything as far as if you've checked what has been mentioned or not and what you've found. We rally can't fix it for you over the net, you're gonna have to do that, but if you want help you need to let us know what you have or haven't done and take a lil of our advice. Just sitting here bumping post and waiting on someone to post isn't gonna help you, checking things and trying things will. If you have a manual get it out, if not download the one online, search for it and you'll find it.
    Jul 2003
    1988 lxi 2dr coupe
    Newport, Pa
    i have checked this is my second post on the matter and ive spent a little over 4 hours trying to get it fixed by myself and in no way am i trying to get you guys to fix it it i just need some help . thats what forums are for .... or it might just be me?
    Jul 2003
    1988 lxi 2dr coupe
    Newport, Pa
    theres little spark so i changes my coil and coil wire and that seems to be working fine
    10/Honda/Ridgeline
    NJ
    On a fuel injected when the engine light pops up, check for the code under the seat on the ECU. Probably you lost the injector resistor box. I had a problem with the car cranking but never start up and it was a loose connection bwt the resistor box and the clip connector. CHeck the line to see if u got fuel pressure at the fuel filter inlet neck.
    If the main relay is at fault, pull that thing out and resolder the solders on the back of the PC board. It fixes it. Even a hairline crack on the old solder prevents car from running.
  1. exi wont start
    By beran24 in forum EFI Tech
    Last Post: 11-26-2009, 05:27 AM
  2. 86 accord start then died then wont start again
    By khmerproduction in forum 3geez Accords
    Last Post: 02-03-2006, 08:07 AM
  3. 87 LX-i wont start...need help
    By whyterice in forum 3geez Accords
    Last Post: 02-08-2004, 09:20 PM
  4. Car wont start after i wen out of GAS
    By LeXUS_ in forum 3geez Accords
    Last Post: 07-05-2003, 02:48 PM
  5. Car wont start after i wen out of GAS
    By LeXUS_ in forum Classic Honda Community Chat
    Last Post: 07-04-2003, 02:50 PM
