hey i got a 1990 accord exr i wanna swap the motor and im not sure what to got to im new at this stuff and i need some help
what is the best engine for a 1990 accord exr
H22A ... nothing more, nothing less.
My Project thread https://www.3geez.com/forum/project-c...dan-build.html
My Flickr: http://www.flickr.com/photos/jdmca5/
what is the cost of an H22a and does it drop right in or is there other mods to do this and what about the tranny will it be ok or does it gotta be switched too
you have two choices: H22 motor or F20B motor from accord SIR-T. the power is the same. the price will be diff.
power are not the same.
Nom: F20B
Voiture d'origine: Accord SiR-T
Marché: Japonais (JDM)
Configuration: DOHC 16 valves
Alimentation: PGM-FI
Type: VTEC
Ratio de compression: 11:1
Alésage x course: 85mm x 88mm
Déplacement: 1997cc
Puissance: 180cv à 7000 tours
Couple: 142lbs-pieds à 5500 tours
Nom: H22
Voiture d'origine: Prélude VTEC 92-96
Type: VTEC
Ratio de compression: 10.6:1
Alésage x course: 87mm x 90.7mm
Déplacement: 2157cc
Puissance: 200cv à 6800 tours
Couple: 161lbs-pieds à 5500 tours
Nom: H22A
Voiture d'origine: Accord Type R 97-01
Type: VTEC
Ratio de compression: 11.0:1
Déplacement: 2157cc
Puissance: 220cv à 7200 tours
Couple: 163lbs-pieds à 6500 tours
Nom: H22A1
Marché: Nord-Américain (USDM)
Type: VTEC
Ratio de compression: 10.0:1
Déplacement: 2157cc
Puissance: 195cv à 7000 tours
Couple: 156lbs-pieds à 5250 tours
Nom: H22A4
Voiture d'origine: Prélude SH 99-01
Type: VTEC
Déplacement: 2157cc
Puissance: 200cv à 7000 tours
H22 would be the better bet cause of the larger displacement. Who needs the 2.0 anyway. besides, talk about making power at the high end.
no question about this, the h22a is a direct drop
but that's a 4th gen, this is a 3rd gen forum
~<+045+ygH05+>~
please use the Post Reply button to ask new questions about the same topic... instead of posting a new topic with the New Thread button.
