This problem started out as infrequent, but is happening more often.
Symptoms: Normally, I will turn the key to the "On" position and wait for the two seconds until the Check Engine light turns off before starting the car. It turns over immediately this way. When it has "the problem" I actually fail to hear the "click" from inside the dash when the Check Engine light goes off and then the engine doesn't catch, almost like it's getting no fuel. If you turn the key off and back to On a couple of times until you hear the click it will start.
My educated guess is the main relay. The shop manual says that the secondary part of this component energizes the fuel pump for two seconds when the key is first turned to On. Anybody else go through this before?
Thanks!
