I have an 98 SiR Prelude with 63,000 Km on it, when would be the best time to get the Timing belt changed ?. Would it be an expensive job to get done and how much would it cost to get the Timing Belt ?.
How much Bhp and Torque would you expect to get from a Reactive Stainless Steel two Piece Manifold ?. Also would it be worth getting a Cat By-Pass Pipe for my Car. I have a Stainless Steel Header from Reactive and also a full Stainless Steel Ziegan5 exhaust one off from the Cat back, so the only thing remaining that is origional to the Exhaust would be the CAT. What difference would it make in noise and Performance wise to having the CAT removed and replaced with the Cat By-Pass Pipe ?. Would the Cat by-Pass Pipe by made of the same steel as the origional exhaust and would the By-Pass Pipe be tapped to accomodate the Cat Sensor ?. :super:
