Results 1 to 5 of 5
Thread: hmm...fuel injectors = rough idle??
    Jareds 89 LX-i's Avatar
    Apr 2001
    Black '89 Accord LX-i sedan
    Mills River, NC
    Question hmm...fuel injectors = rough idle??
    Ok lately my car has developed a slight roughness, or maybe more of a "miss", only at idle. Everything above that is perfectly normal, and she's got just as much power as she's always had. I've been brainstorming a few things, but I'm not sure. At first I thought maybe one (or both) of the intake manifold/throttle chamber gaskets were leaking, since that's what happened on my sisters Maxima and it caused it to be rough only at idle. But all those gaskets were replaced when I did the head gasket back in October, and I've only put 20k miles on since then, so it shouldn't be that. I also thought maybe vacuum hoses, which it still could be, but I looked over them all and all seemed to fit tightly and none were dry or brittle. Also on a vacuum test, I was getting 21 in-Hg of vacuum, and it didn't flucuate at all, so I would think that would show a vacuum leak if there was one, maybe (?). I haven't done a full tune up lately, but it hasn't been that long. I replaced the wires just a couple months ago with NGK's. Spark plugs might be about due though, so maybe I'll just do a tune up anyways.
    Now I'm thinking either fuel injectors or distributor. I know the distributor has never been replaced, and only 2 fuel injectors were replaced (@ about 180-190k), the other 2 are still original with 294k. I know when a fuel injector went out on my sisters Maxima it didn't give any warning (roughness or anything), it just up and quit (then it got rough! lol). Would dying injectors cause a rough idle? I'm sure a dying distributor would, but I'm not sure how to check that (if anybody knows, please tell). If I remember correctly, I can check the resistance of the injectors with an OHM meter, right?
    Any other suggestions? This isn't a "rough as a pig" type thing, just a little roughness that's enough to be annoying. Sorry if this sounds kinda jibberish, just typing as I'm thinking here, lol
    Thanks!
    -Jared
    Apr 2001
    Mills River, NC
    damn it....wrong section. Supposed to be in technical...sorry!
    *smacks himself on the head*
    -Jared
    if it's sealed up ok then I'd check the ignition (plugs, wires, coil)
    Eric
    1988starter
    Guest
    Get a new cap rotor pcv valve and clean the throttle body for me that was about 20 bucks and it did wonders.
    Apr 2001
    Mills River, NC
    Ok I'll try the tune up first. If that doesn't cure it I'll tinker around with some other stuff.
    Thanks!
    -Jared
  1. Replies: 2
    Last Post: 01-17-2012, 05:40 AM
  2. Rough idle and rough in high rpms
    By Tread in forum Carburetor Tech
    Last Post: 11-12-2011, 07:37 AM
  3. Very Rough Idle
    By JDMPrelude23 in forum EFI Tech
    Last Post: 03-31-2011, 05:26 PM
  4. Rough Idle
    By rrhodes in forum 3geez Accords
    Last Post: 05-23-2008, 04:17 PM
  5. Very Rough Idle
    By hondamanlxi in forum Carburetor Tech
    Last Post: 07-29-2003, 06:14 AM
