Aight here's the deal. The #1 cylinder has no compression while cranking. The #2 cylinder has 125lbs. The #3 cylinder has about 135lbs. The #4 cylinder has about 140lbs.
While running the number one cylinder measures 90lbs???Why would it be 0lbs cranking and 90lbs running????
I checked the the timing marks on the cams and they line up exactly. The crank is exactly on #1 TDC. The #1 spark plug is getting spark but it was the only one that was carbon fouled. Before i reinstalled the head I had it checked for bent valves and he said it tested out ok. There is no oil in my antifreeze or vice versa. I dont know , i feel like ive tried everything/
Please help..thanks guys
