Results 1 to 5 of 5
Thread: Gas down, RPMS up.
    LX User 88accordlxcarb's Avatar
    Jan 2003
    '88 Accord LX(carb)/'92 Infiniti G20/'00 Infiniti I30/'88 Oldsmobile Cutlass Ciera(286,000 miles), 2004 VW Passat, Golf Cart...
    Middle Georgia
    Gas down, RPMS up.
    When the car is cold and i just drive without warming it up, it runs fine in gear. Then when i put it in netural(stick shift) and just coast to a stop sign or something, the RPMS go up to 3,000 or so and stay there until i push the clutch in. I dont have to put it into gear and let the clutch out, i just have to press the clutch. Does this everytime, until the car is warmed up, then it works normal. The car runs fine, no sputters or anything. With a rebuilt engine, it idled extremely well, but now i notice a slight rumble in the idle(which i guess would be normal idle for a 15 year old car).
    Also the gas MPH has gone down from around 35MPG to ohh say 20 or so(or a little less), like i said it runs fine.
    I am thinking a vacuum line has fallen off, but it seems weird that the clutch would have an effect on the idle, since it is chain driven.
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    Have someone push the clutch in while the car is behaving as described. Maybe the clutch cable is moving around and hitting the throttle cable. Your best bet right now would be to see what is going on under the hood when your car behaves the way it does.
    BTW, your clutch is cable driven.
    I hope you find this helpful.
    3axap.
    Jan 2003
    Middle Georgia
    Cable...chain, blah blah, its a wire..haha.
    Thanks i will try that.
    Oct 2001
    87 Accord EX , 5spd , Manual
    i have heard PCV valve causing problems to idle with clutch ! don't ask me how is that related ! ?
    Mike
    Mine does the same thing! I always thought it was weird.... I guess I'll have that checked.
  1. RPMs
    By canadian357 in forum 3geez Accords
    Last Post: 04-01-2008, 03:57 PM
  2. low RPMs get too much fuel
    By HondaBoy in forum Carburetor Tech
    Last Post: 08-01-2005, 07:24 PM
  3. stumbling at low rpms
    By 5spdaccordlxi in forum Performance
    Last Post: 08-01-2005, 05:26 PM
  4. Clarify, About RPMs
    By AccordAddict in forum Performance
    Last Post: 08-20-2004, 07:05 PM
