Results 1 to 15 of 15
Thread: speakers not working?anyone help please?
    Oct 2003
    Unhappy speakers not working?anyone help please?
    I hooked up a 91 honda prelude deck and it worked but the volume was really low. does anyone know what's up? I had to turn up the deck all the way just to here wispers of sound.
    2007 pilot
    Lv, nv
    well... it could literally be a million things. are you sure all your wires were hooked up right? i fixed a similar problem when my brother incorrectly installed a stereo in his old datsun (he put the positve wire to the positive terminal, and ground the negative directly to the chassis, plus he spliced a bunch of wires together... didnt bother to find out what or why). anyway, it could also be the deck itself. since its from an old prelude, ill assume its used. did it work ok before you installed it? if it did, then youve either got some stereo lines crossed, or you dont have enough power to the unit itself.
    LX User catalin's Avatar
    1986 Accord Hatchback
    Surrey, BC, Canada
    Re: speakers not working?anyone help please?
    Are you sure it's a Honda stereo?? Sounds like it's a pre-amp only output deck... Definately a problem with the deck.
    either the radio is bad or you have a short in the wires
    Surrey, BC, Canada
    Or it could be a Honda Bose head unit that's a pre-amp only.
    Vinny's Avatar
    Aug 2003
    Here, not there
    Usually don't preamp only radios use RCA's????? It definitely sounds like wires grounding out or an internal problem like a bad output IC
    chicago , il.
    nope from the sound of it , since it's from a prelude. which they porbaly all have amps.
    you more than likely gotten a radio the is preamped only.
    Surrey, BC, Canada
    I have never in my 10 years+ of installing professionaly encounter a stock/factory head unit have RCA pre-outs.
    Surrey, BC, Canada
    The newer 98 plus Preludes have an amp to the rear speakers... the only ones I know that have some sort of an amplifier.
    Since 88Accord2SE is not responding at all, we'll never know what he has, for sure.
    Jun 2002
    1988 HONDA ACCORD LX
    from ALASKA stationed in Korea
    my friends explorer had preouts, and its a 1994.
    HostileJava's Avatar
    Northampton, PA
    another vote for preamp outs.
    Vinny's Avatar
    Aug 2003
    Here, not there
    And I thought I'd been smoking too much crack,
    I dunno of any other way to run preamp except RCA's, and the old style DIN connectors. Could have just been me though
    Northampton, PA
    preamps can be run using regular wires, it's just another way for the oem to make things tougher to tamper with.
    Surrey, BC, Canada
    I'm sure they were'nt RCA preouts, unless someone has wired them in without you knowing.
    iamvandemon's Avatar
    87' dx sedan/88' lxi hatch
    NEPA!
    Who need wenches when ya got a shiny set of wrenches?
    Grease Monkey forever!!
  1. speakers
    By Spoolin'12 in forum Interior & Exterior Care
    Last Post: 09-19-2004, 03:22 PM
  2. Speakers Whine And Engine Noise In Speakers
    By wallyyfm in forum Interior & Exterior Care
    Last Post: 07-28-2003, 06:26 AM
  3. different speakers
    By bambamky in forum Interior & Exterior Care
    Last Post: 07-13-2003, 09:12 PM
  4. what speakers?
    By 89accordboi in forum Interior & Exterior Care
    Last Post: 11-23-2002, 06:47 PM
