Results 1 to 3 of 3
Thread: timing belt...
    LX User Gregs89AccordLxi's Avatar
    1989 Honda Accord Lx-i Sedan
    High Desert, Southern California
    timing belt...
    I've been putting it off for a while but i need to replace the timing belt (got a 100,000 miles on it), i would try to do it myself but i dont want to chance messing anything up... I got some quotes to get it done, the cheapest was $205. Does it sound like a good price? or should i keep on searching, Thanks
    S.F. Bay Area
    It's about average if includes an original Honda timing belt. I would recommend you change the tensionner as well.
    Claude
    Erika - [email protected]
    '89 Accord LX 100% Stock
    Claude - [email protected]
    '89 Accord DX 100% Stock
    Nov 2000
    I have heard several people talk about changing the tensioner which doesn't sound like a bad idea. I am on my third timing belt and so far the tensioner has held up well. Last time I changed the belt (at 160,000 miles) the tensioner still seemed brand new. So, here I am with 196,000 miles on the original. The tensioner gets very little lateral force on it and contains roller bearings so I am not sure it is essential to change it, but why not.
    Make sure that price includes the water pump! ONLY go with a real Honda water pump. They are $37 online which is actually cheaper than aftermarket and Honda's bearing/seal design is patented. I used a good quality, new aftermarket pump las time that cost me $45 and the bearing became noisy after only 18,000 miles. I considered it alesson learned an installed an Honda pump. I also, change the thermostat while I have the coolant drained. It's cheap insurance and that way you will never have one go bad on you.
  1. I need timing belt help
    By dmitch31 in forum 3geez Accords
    Last Post: 05-30-2007, 10:40 AM
  2. Timing Belt
    By 89HondaAccord in forum 3geez Accords
    Last Post: 03-10-2005, 07:54 PM
  3. Timing Belt
    By 89HondaAccord in forum EFI Tech
    Last Post: 03-09-2005, 04:30 AM
  4. Timing belt
    By 89AccordLvr in forum 3geez Accords
    Last Post: 03-20-2003, 05:13 AM
  5. Timing Belt.....
    By 3G Jester in forum 3geez Accords
    Last Post: 01-03-2003, 12:06 PM
