Results 1 to 5 of 5
Thread: Advance my timing. NO PING??
    LX User 89accordlxi's Avatar
    see user name
    IA
    Hello y'all. I went out last night and finally decided to advance my timing. I don't have a timming light, so i was just going to do it by ear. How far does the distributor normally rotate? I ask this, because I turned it counter clockwise about 1/4"-1/2" and it didn't seem to want to go any farther. Is this normal?.. If so, then that means I advanced it as far as it will go. Even so, I still get no pinging, even at high revs. Does this sound right? Is the ecu counter acting the advance by retarding the timing??? If so, what would be the purpose of advancing the timing if the ecu is just going to adjust it self back to normal???
    Any insight on this matter would be great.
    Thanks
    Peace out....
    89 Lx-i
    Performance: K&N filter,custom CAI, Accel coil, MSD 6aL ignition, magnecor wires, high flow injectors, FPR, sport exhaust,Tokico springs/struts
    Appearance: white gauges, side markers, headlight conversion, clear bumper signal/fog light conversion, SE-i center armrest and cupholder, SE-i leather seats
    17" ADRs with 205/40/17 khumos
    future plans: 16" or 17" rims(can scratch that one off the list 9-12-02), headers-high flow cat.-cat back piping. Rear disc brakes from SE-i, reground cam.
    Oct 2001
    87 Accord EX , 5spd , Manual
    did you do it clock wise or counter CW ?
    MIKE
    see user name
    IA
    I'm sure it was counter clock wise.( to the left)
    later.
    89 Lx-i
    Oct 2001
    later.
    MIKE
    The ecu may be able to couter act the vaccum advance if it's not hooked directly to the manifold... but it can't affect the physical timming since the distributor is locked with the rotation of the cam... only on new electronic ignitions does the ecu adjust timing.
    I think the electronic ignition uses a cam position sensor or someting...
  1. advance my timing for mpg?
    Last Post: 04-22-2011, 05:22 PM
  2. how can i advance my timing!
    By salgmz in forum EFI Tech
    Last Post: 03-18-2007, 10:11 PM
  3. Timing Advance
    By 1989se-i in forum 3geez Accords
    Last Post: 11-16-2002, 03:21 AM
  4. How to advance timing II
    By LX-biker in forum 3geez Accords
    Last Post: 07-22-2002, 07:25 PM
  5. how do i advance timing
    Last Post: 07-15-2002, 03:20 PM
