Noob Question.
What sizes are they and how many? system is down and going to replace all.
thanks
Drew
Noob Question.
thanks
Drew
3rd Gen Accord Shirts and Stuff
Some of my Drawings
85 IROC Z28,TPI 355ci,700r4, 9.4:1 Aluminum pistons, COMP CAMS street/strip hyd roller cam, HYE TECH ported/polished heads, HOOKER Longtubes, Full 3 inch exaust NO Cat, TPIS alum fuel pressure reg, ACCEL distributor, custom programed chip from Performance Resource, Competition Engineering shocks. 10/90 front 50/50 back. Eibach drag springs up front. Auburn posi. SLP cold air induction and airfoil.batt relocated w/ kill switch.Still on street tires (Kuhmos all around)SOLD
87 IROC Z28, TPI 350ci, 700R4, 3.42 Posi, 4 wheel disk, Completely Stock (Wrecked)
1987 LXi 2.0 auto
Front door speakers are 5.25" while the rear dash is 6.5". You can upgrade to rear 6x9 boxes if you get the boxes out of an Accord SEi 3G. I used 6x9 boxes from a 92 Accord Ex, I had to cut the hole a little bigger and drill new mounting holes in the back dashto fit it. Good idea at replacing the stock stereo, it really blows.
thanks
Some of my Drawings
1987 LXi 2.0 auto
The LXi coupe also came with 6x9's in the rear. I ought to know as I have replaced mine.
hmm..guess i need to check..
walmart has el'cheapo system, 200 watt cd player and 2 6 1/2 fronts and 2 6x9 rears for 140..
hmm dunno
Some of my Drawings
1987 LXi 2.0 auto
My car took 6.5's in the front doors. Don't buy Wal-Mart stuff unless you have to or it's at least Pioneer. The cheap stuff won't sound as good.
the front speakers always 6.5".
Yeah I did the same thing. Had to do a little metal cutting to make them fit, but it was all good.Originally posted by DBMaster
I wouldnt even bother with the boxes. They sound just as good without them.
Thinking about getting a new 3g...
cool...
140 for 4 speakers and 200watt cd player..new in box.
just for now since the current ones are way fried. pop and crackle.
Some of my Drawings
1987 LXi 2.0 auto
Mine came with 6x9's (cheap dual cone) from the factory. I did not have to do any modification to install the Clarion 2-way 6x9's that I have in there now. I installed them in the stock grill/enclosures.Yeah I did the same thing. Had to do a little metal cutting to make them fit, but it was all good.
hope thats the way mine are:smokin:Originally posted by DBMaster
Some of my Drawings
1987 LXi 2.0 auto
Really? It must have been the way my 6x9's needed to settle. Either that or you were lucky. Who knows.Originally posted by DBMaster
His were probably not as deep (shorter throw) as yours.
The Clarions did not have huge magnets and they had pretty shallow baskets. Another limiting factor I have noticed with the stock enclosures is that some 6x9's that have the thick plastic frames around the edge of their metal frames won't fit under the stock grilles.
Lots of possibilities. I was not going with anything radical so I had no issues.
If you're going to go cheap, go Pioneer. Get their higher end models.... with the 3 way speaker and rubber surround. They sound excellent.
i got a 86 and 6 1/2`s in all corners, had to cut out the plastic part in the door gor the mag`s to fit, door still goes down fine too!..... took me about 20 mins to get it all in!
I have Sony Xplodes in the front, 5.25" 3 way. They were $45 at Wal-Mart. Pretty good for cheap. My rear are Polk Audio EX 6x9 3way witch are much better than the Sonys.
I have 6.5's all the way around. In the front I had to cut the little plastic basket a little but it was worth it.
yep! thats what i did too, very worth it huh!!!!! sounds better then 5 1/4`s i didnt think it was wise untill i did it, then it was like whoa why didnt honda just make them like that anyways!!!!:smokin:Originally posted by 86 accord in C.P.
