Results 1 to 11 of 11
Thread: Exhaust smoke
    Oct 2002
    1988 Honda Accord LX
    New Jersey
    Exhaust smoke
    Wassup....
    What causes smoke to come out the tailpipe. It seems like everytime I put oil in my engine, I blow out huge amounts of smoke when I am doing 70mph and I can't seem why. Then once the car is driven for a few days it doesn't smoke anymore. Could an oil leak cause this or is it something else?
    Please tell me is going on
    Holla back...
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    what color is the smoke? smoke can mean a number of different things depending on what color it is.
    Nothin' 2 Old Racing
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    blue smoke means your car is burning oil...
    -Harvey
    if you put too much oil it will smoke untill the level drops.
    Oct 2002
    New Jersey
    it's white smoke that comes out the tailpipe...what could it be?
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    if its white thats a sign of water getting where it shouldnt be. Now if its just for a short while its probably just normal condensation coming from the cat. If you have white smoke ALL the time, then you could have a bad headgasket. Are you sure you get white smoke ONLY after you change the oil or does it smoke when its cold?
    Oct 2002
    New Jersey
    my bad..it's not white..it's a dirty white grayish color. it's probably because i put 2 much oil in the engine. the level of the oil is a little under the 2 hole of the oil dipstick. did i put 2 much oil in the engine. what happens if you have your oil level a little under the second hole? would that cause smoke out the tailpipe? where should the oil level be.
    the oil level should be between two holes.
    grey smoke = piston rings. your engine will need to be rebuild in the future, and i mean with in next year. it will smoke more and more if you don't rebuild the engine or change piston rings.
    DX User syclinsam's Avatar
    1986 / Accord LX-i / Hatchback! & 89 SEI 5spd sedan
    I realize this an old thread but it hits close to my concerns and I couldn't find a straight answer, maybe I missed it or, either way here goes.
    My 228,xxxmi 86 lxi hatch now apparently blows alot of blue smoke which i know is burning oil...
    To make a long story short, my brother changed the oil and put the 10W-40 I had bought for the tranny, into the engine. It had 10W-30 in it and didn't smoke except a bit of white at start up. He also overfilled it, not by much by still overfilled it.
    My questions are,
    would changing the weight of the oil lead to smoking?
    would changing the weight of the oil cause damage to an older engine like ours?
    i read in a thread that the engine will burn off oil overfill, does this cause damage to the engine?
    i plan on changing the oil back to 10W-30 when I have the chance to get home this week...any other suggestions? its buggin me cause i put alot of work into the car to get it inspectable again, and now it is soooo close and it starts blowing blue smoke...WTF...
    1987 ACCORD LX
    ONTARIO CANADA
    If It Comes Out Ur Taile Pipe Them The Valve Seals Are Done Or Close To It Cause When U Put Oil In It Pools At The Top Near The Valve Seals I Can Replase Them With A Coat Hanger Threw The Prak Plug Hole Holding The Valve As U Torch The Seal To Take Off Then Heat Them A Bit And Force Them On Its Ease As That I Did It For A Frind On A 4th Gen Accord And It Works Better Then Paying For A Head Gasket And When Ur Doing This The Cylinder Ur Working On Make Shure Its Up So If U Slip The Valve Wont Run Away The Cylinder Will Hold It
    i think it is my seals too. i have to replace my axles and seals. sounds like a fun days work!
    thanks!
  1. exhaust smoke
    By gp02a0083 in forum 3geez Accords
    Last Post: 03-23-2011, 02:07 PM
  2. how do i stop exhaust smoke?
    By A18A in forum 3geez Accords
    Last Post: 03-17-2006, 06:57 AM
  3. Smoke from exhaust at start-up???
    By DaveC in forum Classic Honda Community Chat
    Last Post: 01-19-2005, 10:27 AM
  4. White Smoke from exhaust
    By rosy87lxi in forum Classic Honda Community Chat
    Last Post: 03-29-2004, 12:45 PM
  5. exhaust smoke
    By swiftly_driven in forum 3geez Accords
    Last Post: 11-17-2003, 06:16 AM
