Results 1 to 8 of 8
Thread: Vibration.... woo.
    Vibration.... woo.
    Ever since I've had my lower balljoints and axles replaced, my car has been vibrating upon acceleration, at any speed. Esp on hard acceleration. It never did anything like that before.
    First time I noticed it, I took it back. He replaced an axle which was defective.
    That helped a little, but not really. The vibration is still present.
    Today I went and had my tires rotated, balanced, and for the hell of it had them check the air pressure in them.
    Vibration is still there.
    I call my mechanic back, and he says to drive it for 100 miles because the axles might need to be "broken in" since everything is so tight. Ok.
    What should I do? I don't want to screw up my car anymore.
    Mar 2003
    like what kind of vibration????? like ur Stearing wheel jearking? or what?
    1992 Tsi AWD
    Status: Fixed.
    WANTED ANY 3GEE IN FL!
    Nah the entire car vibrates. I can feel it on the clutch pedal, steering wheel, and gas pedal. Not that much but I can feel it.
    Aug 2003
    1988 LX
    Mid-Hudson Valley, NY
    When I had my left axle replaced recently, the car drove same as before. When my right axle was replaced with one that did not have the damper weight (manual transmission), I started feeling some vibration, even tough it is not as excessive as yours. Next time when I replace the right axle, if I can find one with the damper, I would probably get it installed.
    SEi User danronian's Avatar
    1989 Honda Accord Lx-i, 1975 Chevrolet Malibu Classic
    Boyertown, PA
    I would try driving it the 100 miles b/c I really doubt a vibration will hurt the car all that bad.
    Did you get the front end aligned afterwards? Also go over the front suspension to make sure nothing is worn out.
    Well the front suspension should be fine, I know for a fact that the lower and upper balljoints are good. He says everthing else is tight.
    I have a feeling it is the axles he used. he said they were refurbished/rebuilt axles. They were 111.00 apiece. I might go back and tell him to put different ones on since these have a warrenty.
    The car also isnt running right either, feels like it has little acceleration.
    Mar 2003
    hmmmm, Little acceleration, I think there is something binding up.
    1992 Tsi AWD
    Status: Fixed.
    Well I've decided to take it back and tell him to fix it right or take off the axles and give me a refund, since they are under warrenty. He's been jerking me around and I don't like it. Honda told me the axles were cheap, another place said the axles were the wrong ones. So whatever, most everything is pointing to the axles. I'll get OEM ones (which I thought he was putting on) and be done with it.
  1. Vibration
    By billyaccord in forum 3geez Accords
    Last Post: 09-27-2004, 07:55 PM
  2. Vibration and my Sub
    By MrBen in forum Interior & Exterior Care
    Last Post: 03-08-2004, 10:50 PM
  3. getting rid of vibration
    By 89cordlx in forum Interior & Exterior Care
    Last Post: 12-01-2003, 10:39 AM
  4. Very Bad Vibration
    By BigCook in forum 3geez Accords
    Last Post: 04-17-2003, 04:27 AM
  5. Vibration
    By kennycm in forum 3geez Accords
    Last Post: 09-18-2002, 02:40 PM
