Hi guys,
after changing the head, i noticed an oil leak at the timing belt side, below the servo-level. (part of the servo pump has oil on it
removed the belt (upper) cover, and the visible oil trace is at the head gasket level. however, there is some oil on the head below the valve cover gasket as well (same side), but not that much as below the head gasket level
the question is: could a head gasket leak oil without any other symptoms (the car runs great...no mixed coolant/oil)?...or should i focus on the valve cover gasket/camshaft seal (both are changed at the same time as the head...)?
peace!
