Sometimes, the car won't start. My motor reves when I turn the key, but it won't stick. Can you help?
okie let the novice mechanic diagnose this:
sounds like fuel problem
did u try pumping on the gas a couple times then try starting it again
check your fuel filters, friend of mine had the problem, he changed the filters.....problem solved! Also check your ignition system(spark plugs, wires, distributor cap &, coil)
