Results 1 to 11 of 11
Thread: How low with 17" rims?
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    How low can I go if I slam on some 17" rims? I dont want no scraping I thought about the H&R's but i'd like to go lower.
    Link to my 3geez garage
    Sep 2003
    17"s uh go down 3 1/2" lil bouncy, but very fun!
    S.Glastonbury, CT
    I have H&R's and i would like to go lower. The rear is nice with my system and crap back there but the front is to high. As much as i hate sleeve coil overs im probably going to get the Ground Controls because i have to worry about scraping when i put the Xenon kit on. Plus you can always change it when you want. 88Lxi68's car rides nice with the Koni's so it would work for me.
    goldyaccord's Avatar
    Ford work Van
    Tigard, Oregon
    Think of H&R's with the adjustablities.... Once you get past about 2.75 inches of drop, it gets alittle bouncy due to the strut going out of it's designed travel.
    getting the struts weather it's Koni's or Bilsteins rod's shortened that will help a ton.
    sorry guys v8's rule
    Jan 2003
    Denmark/Europe
    Rob--> Is your rims 17"?
    Would a 2.5 inch drop work?
    S.Glastonbury, CT
    Yeah those are 17's in the picture but im parked on a slant so the front is actually higher that that. I find it hard to pick out the proper spring to fill the gap because i have Eiback Sportlines on my other accord and the drop is more than advertised. I would look through the pictures to see what others have used. Also keep in mind the rear of my car has a lot of weight in it so its down about an extra inch probably about 2.5 in the rear.
    Ford work Van
    Tigard, Oregon
    My car below have 17's and it's sitting on a 3.5ish drop.
    SEi User jigga225's Avatar
    Louisiana
    yah man I'm on 17's too, my drop...hmmm.. I say bout 2.75"
    http://www.sounddomain.com/member_pa...640_1_full.jpg
    Jan 2003
    Denmark/Europe
    Okay, thats pretty cool. Did you do anything to make the wheel fit in there with that drop? Or does it fit in there "like a glove" with those drops? No scraping when you turn the wheel or anything? Thanks guys! Btw. your drops look good!
    Justin86's Avatar
    Medford, Oregon
    I'm about 3" in the front and 2.5" in the rear but don't plan on having the camber fixed if you don't want rubbing. I was dropped 3.5" in the front with the steelies and I was about an 1" on the ground and I hit everything possible. With the 17" on it would raise the ground clearance 0.5" so keep that in mind.
    Ford work Van
    Tigard, Oregon
    as long as your wheels have 40mm to 45mm offset, you wil not have any rubbing problems except for when of course, you turn and you hit the fender if you compress...
  1. WTB: Looking for a nice set of 16" or 17" rims
    By buzzbomber88lx in forum Trading Post
    Last Post: 01-18-2004, 05:17 PM
  2. ASA 17" Rims
    By litwish in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-12-2003, 06:04 PM
  3. '89 14" x 5.5" 12 spoke alloy rims
    By mindlos in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-08-2003, 12:24 AM
  4. New "original" Honda Rims
    Last Post: 01-02-2003, 12:50 PM
  5. Spare tire "sizing" for 14" rims...
    By offthahook in forum Classic Honda Community Chat
    Last Post: 07-25-2002, 05:32 PM
