Results 1 to 5 of 5
Thread: cam seal leaking...
    accord exi '88, A20A4
    RO
    cam seal leaking...
    ok guys....i changed the cam seal while doing some job on the cyl.head, and it seem to leak. any suggestions about what (else) to do? is there anything tricky to think about there?
    peace!
    peace!
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    Get some moly lube and grease the inside lip of that thing. Your best bet is to remove the rocker assembly and slip the seal on instead of banging it into the bore. If you do decide that a piece of pipe and a mallet is your best option, you have to make sure that it's hammered in at a 90 degree angle with the head and be sure the inside lip doesn't turn itself inside out (took me three seals to get my crank bore to stop leaking so don't feel so bad if you don't get it perfect the first time).
    glorious!
    RO
    thank's for the tips Sabz!
    ok...so should i buy another seal or just keep trying with this one (2 weeks old)?
    peace!
    Sabz5150's Avatar
    Richmond, VA
    I'd get a new one. If you've run the engine with the seal not seated properly, there's a good chance that it may have suffered some damage.
    Honda should be able to put one in your hands for a good price (and with no overnight shipping)
    glorious!
    1988starter
    Guest
    A few dealers had mine is stock.
  1. Replies: 16
    Last Post: 06-12-2013, 10:17 AM
  2. crankshaft seal aka front main seal
    By l0l in forum 3geez Accords
    Last Post: 04-14-2012, 06:50 AM
  3. Oil pump or oil seal? Which is leaking?
    By Pnem3 in forum 3geez Accords
    Last Post: 11-13-2009, 08:35 AM
  4. leaking cam seal
    By rdn in forum 3geez Accords
    Last Post: 02-05-2004, 08:03 AM
  5. camshaft oil seal leaking ! heeeelp !
    By ACCORD EX in forum 3geez Accords
    Last Post: 07-15-2002, 09:30 AM
