Ok...
Cant find walk through for alternator replacement.
gonna go buy one now.
car's battery light is staying on.
alternator had previously been only putting out 12.9-13.1 V. normal i was told is 14+.
This is AFTER i shut off everything in the car. Headlights... AMP, wipers... you get the idea.
NOW its not charging at all.
LXI - so fuel injection is off battery power. hmm it sounds like its missing TOTALLY when the battery is outta charge( i charged it over night so yes, the battery holds a charge) i coasted past 2 red lights to work where the car has been dumped for now.
Im assuming that the alternator i need is a 4 pin cause its an LXI... im gonna get one now.
but alas. HOW YOU GET IT OUT!?!?!?!
some one said you drop the driver front tire and the frame 6-8 inc and pull out bottom. ARE YOU F******* KIDDING?
ARGH. HELP!
