My dad and I were given an '86 accord sedan yesterday for free. Only thing is, it doesn't want to go into gear. The previous owner also said the clutch was worn hardcore. Is this a clutch problem or a transmission problem?
Everything else runs great on this vehicle. Some rust as usual, but its okay since my dad plans on using it for the winter time. I'm not sure what trim level it is, but I think it's a lower class one. It's has the carb and 12valve motor if that helps.
Anyways, if it is the clutch. Will I be able to use the B20A3 clutch in replacement?
