I can not figure out how to line up the top camshaft pulley and the bottom crankcases pulley so that when the timing belt is on it is in alignment and the car will run. I see no marks on the bottom crank case pulley to line it up with the top camshaft pulley. THe top has the marking of top on it and I line it up with the valve cover bolt. Next is the bottom pulley I can't figutre it out all there is is the holes on oppisite ends and then there is a black line on the pulley? How do you set the bottom to line up with the top pulley? Also they have been turned so thre is no way they are aligned. When I did get it back together and thought it was aligned and tried to start all that happened was the fumes came out to the intake. WHAT GIVES!!!!!!!!!!!
