Results 1 to 7 of 7
Thread: best fuel delivery setup for turbo app.?
    Feb 2003
    1989 Honda Accord LXi
    Oklahoma
    Ok, I know i am going to need more fuel with all that air that sean's turbo is going to pushing in, but which type is the best? What would be the ideal setup? Fuel pump, regulator, injectors etc. ?
    "I SEE" said the blind man to the deaf dog.
    Local honda tech got sent off to the air force. If u want something done u just have to do it urself! Having the engine rebuilt.
    shepherd79's Avatar
    Falling Waters, WV USA
    there are no ideal setup. you will have to mix and match on your own.
    Feb 2003
    Oklahoma
    ok, then what are the best of fuel pumps and reg's
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    check my sig for a full list of parts you'll need for the turbo project.
    Nothin' 2 Old Racing
    1988starter
    Guest
    I believe sean found an older camaro V8 fuel pump fit on the stock hanger and supports 400 hp.
    Justin86's Avatar
    Medford, Oregon
    With the injectors you will need to go bigger with the hp. With the turbo and +300hp you might want something like 500cc injectors. It really depends on the other parts you have with it.
    87 prelude si A20a3
    michigan
    Some DSM injectors and a bigger fuel pump with sean's standalone sytem should do the trick.
    87 prelude si
    87 non-turbo supra
  1. fuel delivery problem
    By jamesh23 in forum 3geez Accords
    Last Post: 08-23-2009, 02:47 PM
  2. Fuel Delivery issue?
    By mountain_geez in forum Carburetor Tech
    Last Post: 05-25-2009, 07:40 PM
  3. Fuel delivery prob ?
    By bladekid in forum 3geez Accords
    Last Post: 12-12-2003, 12:27 AM
  4. best fuel delivery setup for turbo app.?
    By 89LXIGUY in forum Performance
    Last Post: 10-22-2003, 09:13 PM
  5. Fuel delivery????
    By '89AccordLX(Rus) in forum Carburetor Tech
    Last Post: 01-13-2003, 08:24 AM
