Results 1 to 12 of 12
Thread: A20A3 Stock Torque
    LXi User Cyric_accord's Avatar
    Jul 2003
    95 Skivic
    Madison, Wisconsin
    A20A3 Stock Torque
    Ok, maybe I'm just too stupid to find it, but I've spent since 3 using the search to find if anyone posted the stock torque numbers on an A20A3, specifically an 88-89... And I went looking around the net and I got numbers ranging from 109 Lbs/ft @5100 rpms all the way to 169 lbs./ft @4000 rpms.
    Now, can anyone tell me a true number, I had always thought it was 122 lbs/ft torque, but i may be wrong after finding all these other numbers.
    Vinny's Avatar
    Aug 2003
    Here, not there
    they are both right. Jareds site lists torque at 122ft lbs And Pauls lists it at 169 Nm. 169Nm=124.64800323169999 ft lbs
    Jul 2003
    95 Skivic
    Madison, Wisconsin
    ok, I figure that was right... i just got thrown off by the one site that told me 109
    Jareds 89 LX-i's Avatar
    Apr 2001
    Black '89 Accord LX-i sedan
    Mills River, NC
    Here's all of them, just to clarify... straight from my brain of genuisness
    86-89 A20A1 (carb) - 98 hp, 109 ft. lbs
    86-87 A20A3 (EFI) - 110 hp, 114 ft. lbs
    88-89 A20A3 (EFI) - 120 hp (@5800), 122 ft. lbs (@ 4000)
    -Jared
    SEi User cdscowboy's Avatar
    90 Nissan 240sx coupe
    Corvallis, OR
    It's geniusosity.....DUH.
    But thanks...I was always wondering the tq!!
    89 Honda Accord Lx
    Ontario, Canada
    Okay explain this one to me! my engine is an A20A3 and Mines carbed... Hows that possible when your list says mines an A20A1??? Mines jspec does that make a diff?
    k-roy's Avatar
    87 LX
    What about the BS and BT motors?
    Hehe, my engine code is BS
    SEi User od2681's Avatar
    2003 Infiniti G35 sedan
    Houston Tx
    haha..BS motor..kinda funny....not htat im hatin or anythin...
    3Geez Veteran 87AccordsterLx's Avatar
    Nov 2001
    1991 Supra Turbo W/ 12k Miles
    Wyotech @ Laramie, WY
    What they don't tell you is that the specs for the A20A1 (carbed) is when the carb is tuned way down for emmissions... Everyone that knows how to tweak a carb can pull way more then 120hp out of the stock carb.
    ~Nathan~
    ~StOcK PiCs~
    LX User Mystic1's Avatar
    Sep 2003
    1988 Accord LX-I 2D
    Crescent City, Ca
    I'm not all knowing but I can read, and my Chilton says a little different.
    There is no A20A1 or A20A3 listed for '86
    87-88 A20A3 (EFI) - 110 hp, 114 ft. lbs
    (per Chilton #30150 pg.3-10)
    Aside from that your both the same. I'm not trying to flame or any thing just thought I would throw that out there.:smokin:
    Learning to tune the radio was easy.. ..now on to the rest of the car....
    *Soon to come
    -Custom cold air kit -dye and paint threw out the inside -new speakers all around
    Quote Originally Posted by diegoaccord
    An Si is more than a Civic
    Check out my ride at
    cardomain.com/memberpage/467671
    Apr 2001
    Mills River, NC
    Well Chiltons is both right and wrong. Then don't list '86 as having A20A1 or A20A3 cuz they didn't exist yet. '86 used different serial numbering from '87-89, and they were referred to as BT (EFI) and BS (carb). They were exactly the same engines, just different serial numbering ('86 BS was exactly the same as 87-89 A20A1, and '86 BT was exactly the same as 87 A20A3). I posted A20 for 86 as well for one because I didn't feel like making seperate lines just for 86 when it's the exact same specs, and A20A1/3 is a more common designation between carb and EFI.
    Now what you posted above is incorrect in a way. '86-87 BT/A20A3 had 110hp, 114 ft. lbs. 88-89 A20A3 had 120hp, 122 ft. lbs. All 86-89 BS/A20A1 had 98hp, 109 ft. lbs
    Trust me on this, I know I'm right
    -Jared
    Sep 2003
    1988 Accord LX-I 2D
    Crescent City, Ca
    You may be right, I'm not going to get in to a debate over you vs. the book. I have seen the shop books be wrong before. I just thought I would throw this out there and see where it went. Besides, dose it really matter, where only talking about a couple of 15 year old ponys anyway.:smokin:
    *Soon to come
  1. stock A20a3 TPS on 70mmTB or aftermarket
    Last Post: 06-18-2008, 05:07 PM
  2. Hi Torque Starter for High Compression A20A3
    By azazel_18_2 in forum 3geez Accords
    Last Post: 11-14-2005, 08:28 AM
  3. stock hp rating for an a20a3?
    By 88'er in forum 3geez Accords
    Last Post: 01-25-2005, 02:51 PM
  4. Want to see: A20A3/4 torque curve
    By Oyvind Ryeng in forum 3geez Accords
    Last Post: 07-01-2004, 01:48 PM
