Results 1 to 7 of 7
Thread: Possessed Engine
    Oct 2003
    Exclamation Possessed Engine
    Ok guys this is getting annoying and embarassing... Whenever i turn my car off and take my key out, my engine starts acting crazy, it sounds like it's going to start back up and shakes and goes crazy, then finally dies. Anye suggestions?
    k-roy's Avatar
    87 LX
    That is called dieseling. Here is something I found on the net.
    The most common cause of that is the failure of the anti dieseling mechanism, sometimes an "anti dieseling solenoid", found on most late model carbureted cars. What is happening is that the throttle is remaining partially open when the engine is shut down, which gives the hot engine sufficient fuel to run without a spark from the spark plugs. Most hot engines have sufficient carbon build-up that remains glowing red hot and acts as an igniter for the fuel. The solution is to make sure that the throttle closes completely when you turn off the ignition switch. Check the throttle stop and make sure that the fast idle on the choke or the "bottom stop" isn't what is stopping the throttle from closing.
    You should check out the howto section on this board for retuning the carb, it is a good idea to do a few times a year.
    2007 pilot
    Lv, nv
    when was the last time you changed your coolant hoses? thermostat? coolant? radiator? any one of these things can cause your car to run too hot, which can cause dieseling.
    Yeah mine does that too sometimes, only when cold. It's actually pretty funny. One time it did it for a couple minutes; I couldn't get it to stop.
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    Didn't you take it for a drive then? Just to see if it made good Horsepowers :lol
    Link to my 3geez garage
    Oct 2003
    Thanks guys i really appreciate it, i'm gonna check it out, now at least i know where to start looking
    1986 Accord S
    la malbaie, QC
    Mine does this only when the car is still on the choke at 2,100 rpm and I shut it down
    Is it bad for the engine to let it do his thing ? When I'm late and I don't let the car run before taking off in winter the choke is still on when I get to school..I prefer to just drop the clutch than let it run for 20 seconds in the school parking lot
  1. my radio is possessed
    By evil88accordLX in forum 3geez Accords
    Last Post: 07-10-2007, 11:28 AM
  2. Speedometer is possessed
    By MrBen in forum 3geez Accords
    Last Post: 03-15-2003, 10:35 PM
  3. Possessed Car
    By kennycm in forum 3geez Accords
    Last Post: 11-08-2002, 12:57 PM
  4. Possessed Car
    By kennycm in forum Performance
  5. my Brakes are Possessed
    Last Post: 07-24-2002, 06:36 PM
