I dynoed my B20A today.
It did the same as yours thegreatdane.
135 lbs/tq @3000
145 hp @ 6800
The difference is that my torque curve is completely flat and the HP was still going up at this point butthe ECU just wouldn't let me go higher
I guess I didn't lose too much low end torque with this intake... in fact I GAINED low end torque (which is odd). I got 120 lb/ft at 2250 and like 130 at 2750.
This is with the PK2/PH3 hybrid rom. The camgears were set at 0.
I'm sure that with an obd1 conversion and some dyno tune, I can reach higher numbers.
I can't say I'm not a bit disappointed with the results since I got higher compression and bigger cams/intake but with a stock ECU, what else can you expect. Oh, one more thing, I still got the OEM exhaust on this car.
I'll scan the sheet soon and post it here. These B20A just jave too much torque. No wonder the tires break loose in 1st gear without too much trouble.
