Results 1 to 7 of 7
Thread: Working On Engine wo/Removing From Car
    LX User it's paid for's Avatar
    Sep 2003
    '83 Accord and yeah, I know it's a 2G okay?
    AL border in GA
    I want to replace the crankshaft bearings, but I was told two conflicting stories . . . can I do this if I leave the block in the car or not?
    I fully realize it will be much easier to do it if the engine is removed, however, I'm just curious if it's possible to replace them wo/removing the engine, & if so, how difficult is it going to be?
    Thanks,
    IPF
    Ummm . . . brella, I needanumbrella.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    yeah, its possible to do, but it'll be a pain in the ass. having to hold up that heavy ass crank while you install the bearings might be too much for one guy to do underneath a car.
    Nothin' 2 Old Racing
    Oct 2003
    B20A SEi
    Oregon City, Oregon
    I did the rings and rod bearings with the block in the car and it was not too bad. Definitely easier out of the car, but quite doable still in the car.
    Gregg
    Sep 2003
    AL border in GA
    . . . great comments . . . thanks very much . . . here goes . . .
    IWLSF's Avatar
    91 GSX - 89 Si - 87 DX
    Oklahoma
    If you're referring to the main caps, just try to do them one at a time first. It might help to loosen all of the caps before starting, so the crank atleast floats down a couple millimeters, giving a little more room for the bearings. Depending on the design, you should be able to just take a flathead and hammer the upper bearing out, letting it come out one side without removing the entire crank. Tap back in with brass punch to reinstall.
    Idaho
    I would take the engine out....would be worth the time....and less chance of fucking up something.
    SEi User deadlight's Avatar
    Jul 2003
    2007 Honda Civic Si RR FG2
    Savannah, GA
    Yeah, I'd pull the motor myself, once you do it a few times, it's easy as hell, I can have my motor out in under an hour.
    Military style fears God not a stranger.
  1. Removing Engine
    By 89lx-r in forum 3geez Accords
    Last Post: 02-16-2010, 01:03 PM
  2. Removing Non-Critical Elements From Engine Bay
    By ArokASE88LXi in forum 3geez Accords
    Last Post: 06-13-2009, 02:21 PM
  3. removing engine. need advice.
    By OldSkoolA20accord in forum Classic Honda Community Chat
    Last Post: 12-23-2008, 11:26 PM
  4. A/C not working
    By my89LXihatch in forum 3geez Accords
    Last Post: 06-22-2007, 10:32 AM
  5. ATTN: Engine working zone
    By Paul Aerodeck86 in forum Performance
    Last Post: 09-19-2002, 08:08 PM
