Results 1 to 10 of 10
Thread: Grinding on Braking
    Chicago IL
    Grinding on Braking
    I just noticed last night that when I brake, I hear a grinding noise that sounds like it's coming from the front wheels. It is only audible at lower speeds when braking and sort of alternates between loud and quiet as the wheel spins. If anyone has any clue as to what this could be, I would be thankful. If you need more info, let me know.
    -Rob
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    Time for new pads maybe. Hard to tell without more info.
    Jun 2002
    88 accord lx
    i just payed like $300 for completely new brakes (rotors, pads, etc etc). and that was like..a month and a half ago. and now i hear grinding. wtf is up with that. i think i got reemed. good thing the guy that did it lives right next door to me, and hes RENTING FROM US! MUAHAHAHAHAHA.
    .//liht
    YK86's Avatar
    Oct 2000
    BC, Canada
    Get your brakes checked ASAP! If your pads are worn, the backing will grind your disc putting gashes/grooves into the surface. Then you will have to replace or machine the discs in addition to new pads.
    www.b20accord.com
    Oct 2001
    87 Accord EX , 5spd , Manual
    check the pads and clean them if they are ok !
    MIKE
    hondaman87's Avatar
    88 honda accord DXE-i H/b 91honda accord wagon, 01 gsxr 600
    medford, mass
    this might be it?
    SEi User
    how can the caliper be touching the rotor?? you either need new pads or the back dust cover behind the rotor is bent and touching the rotor...
    SEi User TeKKnoTeKK's Avatar
    Mar 2002
    88 Accord LX-i 5 spd.
    UT
    If it was the dust cover it would be grind all the time not just when he applies the brake, gotta be the pads.
    -Aaron-
    guaynabo89's Avatar
    FL
    Its pointing to the metal shims that position the pad on the caliper
    S.Glastonbury, CT
    It could also be the caliper is bad or sticking mine is doing that on my new 3g, it has happend on my other 2 accords. Basically when u drive it keeps pressure on the pads. My DX that i had got so bad it would pull to one side and hang up real bad.
  1. grinding gears
    By hootymo in forum 3geez Accords
    Last Post: 01-31-2005, 01:24 PM
  2. Grinding through turns
    By sparksm in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-08-2003, 07:57 AM
  3. Grinding
    By 88' Accord Ltd in forum 3geez Accords
    Last Post: 10-26-2002, 05:53 AM
  4. grinding
    By Bullfrog in forum 3geez Accords
    Last Post: 09-20-2002, 10:32 AM
  5. grinding
    By Bullfrog in forum Classic Honda Community Chat
    Last Post: 09-19-2002, 03:41 PM
