Results 1 to 8 of 8
Thread: metal coolant pipe removal ?????
    shepherd79's Avatar
    Falling Waters, WV USA
    Ok,
    the pipe on my new engine is rusted and one of the connectors broke off. So i started to remove the hole thing, which ended up tearing engine apart. it needed anyway. it had blown haed gasket. I will show the pictures later.
    So anyway, how do you remove the metal coolant pipe that coming from water pump?
    i checked the majestic and it shows that it has O-ring which i figured would be pushed in, but i can't pull it out.
    thanks guys
    if you help me i will OWN YOU ALL A BIG ONE.
    k-roy's Avatar
    87 LX
    I had the same problem when I replaced my water pump. I went back to the dealer for a new pipe to use with the new pump.
    You could use some P.B. Blaster cataylist and let it soak to loosen it.. If its in that condition you might want to consider just replacing the pipe and the pump.
    shepherd79's Avatar
    i can move the pipe, but i can't remove it. i don't know how to remove it.
    what do i have to do? do i have just pull it out or what?
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    just pull it out
    did you remove the bolt that holds it onto the backside of the block?
    carotman's Avatar
    Montreal South Shore
    yup, once the pipe is unbolted, pull hard on it.
    I need these parts!
    shepherd79's Avatar
    sweet, thanks guys.
    i will try pulling hard.
    10/Honda/Ridgeline
    NJ
    the easiest way to do it is using a crowbar and just levering it and yankin on it. I would say, removing ur intake manifold would be much easier to access ur coolant pipe and also time to clean it good.
    shepherd79's Avatar
    ok i got it out. i just twisted and pull it at the same time. it was easy.
    now i have to wait for a new pipe.
  1. Replies: 13
    Last Post: 06-08-2012, 03:11 PM
  2. Changing main coolant pipe.
    By mushroom_toy in forum 3geez Accords
    Last Post: 10-17-2009, 07:18 AM
  3. carb removal and metal vac lines in the way help please
    By GemBawb89DX in forum Carburetor Tech
    Last Post: 10-28-2008, 09:21 AM
  4. Replies: 16
    Last Post: 11-05-2004, 09:21 AM
  5. Coolant Inlet Pipe question
    By skippy124 in forum 3geez Accords
    Last Post: 08-11-2004, 06:54 AM
