I plan on dropping my car and heard i needed camber kits or a sway bar. What are these and what do they do?
I almost got those wheels in 18's for my TL. You don't need a strut bar, it just helps for cornering and keeping your car on the ground. A camber you want after you get an alignment. What happens when you lower a car is, in the front the wheels are crooked. This can be fixed with a front camber kit. IT corrects your front wheels. Also gives your tire more life. Having a low car, the tires wear much quicker. And we all know they is pricey. Camber kit will run you $250-350.
If you lower your car more than 1"-1.5" you will most likely need a camber kit bro, only for the front tho. Some places won't align a car with camber kits installed, so if you do get em make sure that the place won't give you any hassle about em'. The place I bought my wheels from ordered the camber kit for me and also put it on.
-Aaron-
you can always get a 4th gen prelude upper control arm.. they have adjustable lenths to correct the camber.....
you mean 2nd gen prelude?
if you lower your car more than 2" you need a camber kit, or your tires will wear unevenly
Fast and cheap won't be reliable.
Cheap and reliable won't be fast.
And fast and reliable won't be cheap.
"It takes the dough to go."
