I have a dilemma and I am looking for input. I have recently aquired a B20A for my 86 DX and I am trying to figure out the best option for the fuel system. The B20 came as a complete engine, with all the Fuel injection parts, distributor, sensors and engine wiring.
My goals are:
- reliability
- economy
- performance
- low cost
- emissions legal (Oregon Standards, sniffer)
And they all are about equally important. I drive my car 50+ miles a day in a mix of traffic and weather conditions.
The way I see it, there are 3 options:
- Fuel inject it using parts that came with the motor and parts from a donor LXi
- Fuel inject it using parts that came with the motor and parts from other cars (like Prelude ECU or even a GM ECU setup)
- Carb it using my existing manifold and fuel setup but add a Weber 32/36 DGV.
Pros and Cons on each:
Stock FI Pros
- Off the shelf parts
- Good reliability and economy
- Good drivability, no tuning required.
- Reasonable cost
- Sanitary "stock appearance"
Stock FI Cons
- Time consuming and complicated install
- Limiting power potential of B20A
Modded FI Pros
- Good power potential
Modded FI Cons
- tricky install with mix-and-match components
- cost could be high
Carb Pros
- Easy install, using most existing parts
- low cost
Carb Cons
- Requires tuning
- could fail emissions
- potential drivability problems
- may add power, may not
Anything I am missing here? I need to figure this out so I can start gathering parts.
Any advice is appreciated,
Gregg
