Results 1 to 14 of 14
Thread: Need help with what I assume is a break problem.
    HostileJava's Avatar
    Northampton, PA
    Question Need help with what I assume is a break problem.
    So I'm on my way to school and I accidently drive over this piece of garbage on the highway. I come back down from driving over it and my drivers side front wheel starts making this horrible squealing noise. I put the breaks on and it goes away. I hit another small bump and it comes back. I apply the the breaks and it goes away. After doing this for a couple time I couldn't get it to go away unless I had the breaks applied. So I turn around and go home. I took the wheel off and I think I found the culprit, there appears to be a dust cover behind it(?) and it looks all bent. I can't remember if it looked like that when I had the wheel off before. Would this cause that kind of problem? Pictures to follow:
    My question is can I just bend this back until I can replace it? Can i just take it off? Would this be the cause of the problem?
    Vinny's Avatar
    Aug 2003
    Here, not there
    Its just a shield, I say bend it back and see if the noise goes away.
    Oh and no more talking to me on AIM, my bad luck rubbed off on ya
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    either the dust shield is the culprit, or there is something in the calliper. I'd suspect that since the noise goes away when you apply the brakes, that there is something in the calliper.
    Nothin' 2 Old Racing
    Northampton, PA
    I just bent the dust sheild back and took it for a quick test drive. That made absolutely no difference. What is my next step? I know nothing about breaks.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    check to see if anything is in the calliper thats binding up in the pads. Honda disc brakes are SUPER simple. Just look all around and see if anything is caught up in there.
    Vinny's Avatar
    Aug 2003
    Here, not there
    might also wanna try and turn the rotor to see if you can tell where it may be binding up, if that makes sense
    Northampton, PA
    I just turned the car on, put in drive and stepped on the gas. It kind seems random now as to when it goes away, but it always comes back as soon as I step on the gas. My next questoin is should I be able to see between my caliper and rotor? Should they be this close?
    Oct 2003
    B20A SEi
    Oregon City, Oregon
    Read this:
    https://www.3geez.com/showthread.php?s=&threadid=25706
    Try it, it can't hurt.
    Gregg
    Northampton, PA
    I got the bracket off that his holding the breakline, but I can't get the two bolts off of the caliper. I must be a freaking weakling or somthing. Dammit I need air tools.
    Oct 2003
    B20A SEi
    Oregon City, Oregon
    Are you talking about the 2 17mm bolts that hold the mounting bracket? You don't need to pull those to remove the caliper. There is a 14mm bolt on the lower side of the caliper that you need to pull out. Then you should be able to rotate the caliper up and away from the rotor. (if the upper pin is not frozen)
    Gregg
    IWLSF's Avatar
    91 GSX - 89 Si - 87 DX
    Oklahoma
    Time for new brake pads dude.
    Btw, what camera you have? Those are some excellent pictures, I'd like that camera lol.
    Northampton, PA
    Yeah, I ended up taking it to a garage and they told me that it looked like somthing was chewing at the breakpads. So I got to new pads and the breaking is better and no more noise. I prefer a shop do it anyway. I don't like messing with my breaks. I'd hate for them to not work when I need them.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    heh heh yeah no brakes can really ruin your day...... glad you got em fixed...too bad you couldnt do em yourself.
    IWLSF's Avatar
    Oklahoma
    What camera?!!?!?!
  1. uhm, what did i break?
    By 89lx-r in forum 3geez Accords
    Last Post: 02-18-2010, 06:25 PM
  2. the break in
    By snoopyloopy in forum Classic Honda Pics & Videos
    Last Post: 05-30-2008, 02:18 AM
  3. Will I Ever Get A Break!!!
    By my86dx4dr in forum Classic Honda Community Chat
    Last Post: 01-06-2004, 03:33 PM
  4. Parking Break
    By My 89 Accord Lxi in forum Performance
    Last Post: 10-15-2002, 12:52 PM
  5. break in.
    By 88BlackEXi in forum Classic Honda Community Chat
    Last Post: 07-08-2002, 10:12 AM
