Results 1 to 8 of 8
Thread: A/C Charged? How can I tell?
    LX User it's paid for's Avatar
    Sep 2003
    '83 Accord and yeah, I know it's a 2G okay?
    AL border in GA
    Hello - I suspect my a/c is not charged and I'd like to remove it (bought the Accord used and the a/c switch on the dash does nothing) . . .
    . . . I'd like to remove the entire a/c system - perhaps putting it in later - but is there a way I can RELIABLY check to make sure it's not under pressure?
    OR
    Is there a way I can safely remove the pressure from the system myself?
    Thanks,
    IPF
    Ummm . . . brella, I needanumbrella.
    Vinny's Avatar
    Aug 2003
    Here, not there
    Its technically illegal to vent it. If you depress the valve stem on either the high or low side ports and something other than air comes out its serviced, if its just air then hell with it break it open
    Sep 2003
    AL border in GA
    Okay . . . this is great . . . I removed the blue cap and depressed the valve stem very gently . . . a little pressure was relieved and then I stopped . . . I sniffed the area to see if I could smell anything other than "air" but no . . . I carefully depressed the valve again and to my surprise, the airflow quickly stopped . . . I'm guessing total venting took maybe 3 1/2 seconds - if that . . .
    . . . being totally new to a/c knowledge, I then fitted the blue cap and removed the red cap to see if there was pressure on that end . . . nope . . .
    . . . so, can I proceed with ripping out my a/c now?
    . . . any special rules?
    . . . anyone wanna buy it?
    Thanks,
    IPF
    May 2003
    88 Accord LX 88 Accord LXi
    Sounds like it was very low on charge. I'm not sure if you would really smell anything. But remember like Vinny said it is illegal to vent freon. Anyway if there is no pressure when you depress the valve, it should be empty. It should be safe to proceed.
    Oct 2003
    B20A SEi
    Oregon City, Oregon
    Your system is discharged. I've seen this on several cars where there is a little bit of pressure but if you open it, it very quickly empties. If there was any meaningful amount of refrigerant in there, it would take quite a while to vent.
    Gregg
    Sep 2003
    AL border in GA
    Okay . . . I have no idea what condition the a/c system is in (no pun, okay) . . . I want to remove the exchanger (? - you know, the radiator looking thing) and all the other crap . . .
    . . . would it be worth anything to anyone?
    . . . what could I get for it on eBay?
    Thanks,
    IPF
    Oct 2003
    B20A SEi
    Oregon City, Oregon
    The compressor is probably the most valuable piece, but you want to make sure it turns smoothly (by hand). The condensor might be worth something too. It's kinda hard to say exactly how much. Call some wreckers and see what they get for the parts and search on ebay for similar items. That should give you an idea.
    Gregg
    Sep 2003
    AL border in GA
    Thanks - great suggestions . . . I will do that . . .
    . . . this afternoon a friend of mine is letting me use his compression gague (for the cylinders - not the a/c - I'm not that ignorant) . . . let's hope the numbers are good . . .
    Happy According,
    IPF
  1. turbo or charged?
    By RiCANACCORD in forum Forced Induction
    Last Post: 01-18-2005, 04:29 PM
  2. turbo or charged?
    By RiCANACCORD in forum Performance
  3. swaping in a turbo charged b18
    By franks89sir in forum Performance
    Last Post: 03-25-2003, 08:22 PM
