Results 1 to 7 of 7
Thread: clock?
    LX User zchb9's Avatar
    Oct 2003
    1987 accord lx 1985 300zx
    w.v.
    clock?
    Not sure exactly what this falls under so ill post it here and hope someone tells me. Its nothing major just trying to get the clock to work. What fuse is it? I thought it was 11 replaced it but still got nothing. What else could cause it not to work?
    k-roy's Avatar
    87 LX
    It could be burnt out. It could also be grounded out.
    May 2003
    88 Accord LX 88 Accord LXi
    Do you have a multimeter? If you do, disconnect the clock. You should have ground on the black wire.
    Next there should be 12 volts on the white/yellow wire at all times.
    Then 12 volts should be on the Yellow wire with the key on.
    blazin3gen's Avatar
    Good Ol Cali
    check both fuses there should be a fuse under your dash and in the engine compartment under the black box
    May 2003
    It wasn't me. But since it was brought up fuse#2 in the dash fuse box.
    Oct 2003
    w.v.
    thanks ive checked both fuses 1 i replaced the other is good. its late now and cold so im not gonna worry about it tonight but ill try the multimeter thing tom. thanks again
    May 2003
    It also could be a loose or disconnected plug on the back of the clock.
  1. The clock
    By Tomisimo in forum 3geez Accords
    Last Post: 10-09-2006, 01:42 PM
  2. ecu clock ??
    By hondamotorz in forum 3geez Accords
    Last Post: 03-03-2005, 12:03 PM
  3. JDM Clock - Who PM'ed Me?
    By Site in forum Trading Post
    Last Post: 10-22-2003, 12:42 PM
  4. clock?
    By my86dx4dr in forum 3geez Accords
    Last Post: 09-24-2003, 04:57 PM
  5. Help with Clock
    By Rendon LX-i in forum 3geez Accords
    Last Post: 05-02-2003, 08:54 PM
