Hello all,
I have a very direct question. I barely didn't pass the emission test with 3.7 NOx reading above the 3.0 reading.
Other readings: HC: 0.33 / (2.00 limit), CO: 2.57 / (30.00 limit). As you can see, my only problem is the NOx readings.
I have 87 lx accord, carbed. Two years ago NOx was 0.5. and other values were higher than now (this doesn't seem natural).
Then, I had high idle, and definately used 87 gas. I had my carb tuned not long ago and idle is way down and I used 93 gas. Is idle the problem?
I think I may need to add more O2 to the mixture, but not sure.
Main question: should I fill it with say 94, or 87 next time to lower the overall temepature (I think overheated mixture is the problem.) Or should I just fill the whole tank with Alcohol as it will not produce any NOx? Or should I use Hydrozine (if you have any let me know...)?
Is there some easy way to regulate the mixture to lower the NOx?
Please help, and thanks in advance for your response.
