I have an 88 accord lx with 120,000 miles, which nothing compared to how much mileage other engines have. Anyways, i drive on the highway and I floor the gas pedal yet I still can never pass 80mph. what is wrong with my 3g?
Pure Gold "24K"
http://members.cardomain.com/dub88acc
uhmm tune it up.. i dont know what else to say .. my engine has 279*** miles on it .. bout to hit the 280 mark.. and it can hit 120mph.. so i have no clue
- J u n i o r -
Originally Posted by 89ACCORDVTECH
moved to the tech section...
~Nathan~
"There's always something waiting at the end of the road. If you are not willing to see what it is, you probably shouldn't be out there in the first place."
~StOcK PiCs~
im going to answer with what i answer with all the time....partly clogged cat
its not that, i just put pipes onthe car including exhaust
Pure Gold "24K"
You should sell cats. I feel like a fuel filter salesman sometimes.Originally posted by 88potacomobilelxi
Also the air filter is a big cause. I guarentee it is dirty.
Timing could be way off. The belt may be a couple of teeth off.
Did not this guy post a similar thread where I answered twice.
Kroy...knocking up the post count I see. Burning the midnight oil are we?
natsugusa ya
tsuwamono domo ga
yume no ato
Hell yea. I got a 3 day ban for being a post whore. So I have to make up for lost time. I am burning the late night THC oil. This time I am doin it legit with real responses, not just wasted posts.
This guy should check the tire pressure and make sure the brakes are not dragging.
I want to see if you get into any more post altercations...Originally posted by kroy
natsugusa ya
tsuwamono domo ga
yume no ato
check your timing first off. also filters. either change them all yourself or go get an oil change and replace them all. try that see if that works. if not then check your plugs and even your distributer
are there any noises comming from the car? exhaust? engine? intake? roll down the window and listen at low speeds and high speeds. try to get up along a wall or a sound barrier on the high way and listen to the sound bouncing off.
come back and tell us what you find.
-Travis-
lol@ THC oil
Well if you car doesn't go that fast it can be a couple things, especially w/ the carbureted models
1. clogged air filter or fuel filter, bad fuel pump; you should notice poor performace at high RPM in any gear
2. vacuum system leak, make sure the vacuum secondary on the carb is opening, make sure the "A" "B" and "C" lines that go from the top of the carb to the 1 black device mounted near the fuse box are all connected.
3. if you have an automatic low fluid can cause problems especially at high speeds.
4. your brakes aren't fully releasing (not likely)
Eric
