Results 1 to 8 of 8
Thread: How do I wire in tweeters
    Jul 2003
    89/honda/accord lxi
    Jax, Florida
    I just bought a pair of tweeters off of ebay and I'm wondering how I wire them and what do I need. Do I just tap into the door 6.5 speakers? I know how to get the panal off now just need wiring help thank you guys alot.
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    thats a good question Neo...
    do your tweets have a crossover seperate? or built in?
    do you have an amp? or are you running of a head unit?
    Travis
    Jul 2003
    89/honda/accord lxi
    Jax, Florida
    This is what pioneer says about the tweeters
    Features
    Size 3/4"
    Dome Polyester Fiber Soft
    Magnet Neodymium and Magnetic Fluid
    Capacitor for Tweeter Protection - 6dB/Oct
    Surface and Flush Mounting
    Specifications
    Watts MAX. Music Power 120W
    Watts Nominal Power Handling 40W
    Frequency Response 2,5000Hz - 30kHZ
    Sensitivity 90dB (1w/1m)
    Ohm Rating 4
    These are the headunit specifications
    GENERAL FEATURES:
    MOSFET 50W x 4
    XM Satellite Radio Ready
    8 Character display for XM Radio text (no scroll) with GEX-P900XM or GEX-FM903XM
    16 Character display for XM Radio text
    (full display) GEX-P910XM or GEX-FM913XM
    XM Mode (Channel/Category) key
    10-Key Card Remote
    Direct Access to MP3 tracks or XM channels (XM tuner required)
    Rotary Volume Control (Pop-Up)
    EEQ Performance Chip
    3-Band Parametric Equalizer (Adjustable Level, Frequency and Q Factor)
    Easy EQ (EEQ) with EQ-EX switches 10 Factory,
    2 User EQ Presets
    Source Custom EQ Memory (Independent Custom Memory for each source)
    Selectable Loudness Control (Low/Mid/High/Off)
    SFEQ (Sound Focus EQ)
    Additional Independent Bass / Treble Control for Front / Rear
    ASL (Auto Sound Levelizer)
    Two-Way Crossover
    Front/Rear HPF (50/80/125Hz,
    -12dB/oct)
    Selectable LPF (Low Pass Filter) (50/80/125Hz,
    -18dB/oct)
    Sub-Out Level (-12dB to +12dB) and Phase Control
    Independent Subwoofer Outputs
    IP-Bus System Control
    XM Satellite Radio
    MCD Control
    DVD Control
    TV Tuner Control
    Auxiliary Input (CD-RB10 or CD-RB20 required)
    2 External Unit Control
    S.L.A. (Source Level Adjustment)
    Selectable Fader Control
    Hi-volt RCA Preouts (x3 pair, Front, Rear & Sub) (6V)
    Organic EL Display with new white color
    Full Dot design (128x33 + 24x33 pixel)
    Entertainment mode with Full-motion 3D graphic animations
    2 screensavers (Water Board, WRC Racing)
    2 Level Meters
    4 background animations
    Clock Display and Off (Text-only) modes
    Soft-Key mode with simplified graphics and easy operation
    16 Character text display capability
    Adjustable brightness level (16 Mode)
    CD-R PC Link
    Please visit the following link for downloading:
    www.pioneer.co.jp/car/pclink2/
    Cellular Mute input wire
    Clock
    COMPACT DISC
    Track Scan/Pause/Repeat/Random Play
    Audible Fast-Forward/Reverse (CD Audio)
    Playback Compatible with Digital CD-R and CD-RW
    Disc Title Memory (48 Discs)
    CD Text
    AGC (Automatic Gain Control)
    WMA / MP3 CD-ROM Playback
    Pioneer Digital SpeedRead mechanism for faster performance
    ID3 Tag Capability (32 character with Auto-Scroll, On/Off)
    8x oversampling
    3-beam laser pick-up
    1-bit D/A Converter
    Anti-shock mechanism
    If you need more info please tell me and thanks.
    Jul 2003
    89/honda/accord lxi
    Jax, Florida
    are you there?
    88 Accord LX
    Greenville NC
    well it depends on your setup....
    Most folks -----> dont have a parametric eq or crossover then u will need to put a bass blocker on the between the tweeter and you radio or amp (to make sure no low freq go to the tweeters).
    Advanced folks ----> have a parametric eq (eq that seperates then frequncies sends it to your amps it usually will have 2 rca inputs then 2 front out and 2 rears outs and a subwooofer out) or crossover. System that I had hooked up in my old car consisted of the Kenwood eq , 4X20 Blaupunkt amp and a 4 x 200 pyramid .
    The front door speakers are hooked up to the actual deck.(had an issue and had to unhook my amps one day and it sucked to be music less with a 2 hour ride home ..so after that I always leave 2 speakers hooked up to the radio and use bass blockers.)
    Front channel of the eq goes to the 4x20 amp which ran the ..4 tweeters. Rear channel on the eq went to the front of the 4x200 amp (turned gain down)which ran rear deck speakers. Use the subwoofer out to go to the rear channel on the 4x200 amp amd ran them bridged ..I dont remember what speakers had because I have had so many different kinds .... remember running 1 - 10 in bandpass box ..have had 2 -15s rockford fosgate ...2 pioneer 10s ..2 pyramid 12s .... hope thie helps
    The difference is that the eq sites right behind your radio and it send the signal to your amps and and its give a few more options then a crossover gives (never used a cross over so this is from the way i understand it). Cross over sits behind your amp and seperates the freqencies then sends it directly to your speakers.
    Current Vehicles
    2000 Maxima SE
    1999 GMC Yukon
    1988 VW Scirocco
    Jul 2003
    89/honda/accord lxi
    Jax, Florida
    Here are the 6.5s for your info.
    tweeters can be added to any set of speakers but you need a filter to block the lower freq. from going to them.
    you need one of the following
    1. a capacitor wired in series to the tweeter, probably a 4.7uf would work good with those, they should be bi-polar caps with a power raiting of at least 50v if you are powering them with the head unit.
    2. a pair of 2-way crossovers that divides lows to the woofer and highs to the tweeter, you can get them online (ebay, radio shack, etc) or from an old house speaker
    3. get a dedicated tweeter amp that has built in crossovers or an active crossover before it.
    Eric
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    i bought a pair of tweets from radio shack that had a crossover on them already and i just hooked them up to the door speakers. they sounded killer. not a bad investment at 14 bucks for the pair.
    Nothin' 2 Old Racing
  1. Tweeters or new door speakers?
    By Deadhead in forum Interior & Exterior Care
    Last Post: 12-03-2005, 06:04 PM
  2. Suggestions for 3/4-2" Tweeters.
    By Mike's89AccordLX in forum Interior & Exterior Care
    Last Post: 11-01-2004, 10:35 PM
  3. Tweeters in the 94 Accord
    By Imran in forum Interior & Exterior Care
    Last Post: 09-24-2003, 07:01 PM
  4. The Trouble with Tweeters
    By amalgumjoe in forum Interior & Exterior Care
    Last Post: 11-02-2002, 07:36 PM
  5. placing tweeters
    By staticpat in forum Interior & Exterior Care
    Last Post: 10-10-2002, 05:03 PM
